Wifi routers to make cell calls?
0 Members and 1 Guest are viewing this topic. Read 1155 times.
thunderbrick
  • I'm just not right!
« on: 8 Nov 2015, 01:41 am »
I live in a near dead-spot for AT&T cell reception, so calls are often garbled.  I've heard about wifi routers that you can make cell calls through.  Anyone have any suggestions?
'brick
ACHiPo
Re: Wifi routers to make cell calls?
« Reply #1 on: 8 Nov 2015, 02:04 am »
I have an app for my iPhone through AT&T called Ring Central.  It allows you to use wireless to make VOIP calls.  I use it when I travel internationally to save on the outrageous roaming and international rates (~$2/min).  I'm not sure what my company pays for the service, but I'm sure there are other similar apps.
TrungT
thunderbrick
« Reply #3 on: 8 Nov 2015, 02:57 am »
ATT wifi calling:
http://www.slashgear.com/att-begins-rolling-out-wifi-calling-feature-09408979/
THANKS!  I sent that link to the warden, who uses an iPhone.
'brick
Doublej
« Reply #4 on: 8 Nov 2015, 03:03 am »
