0 Members and 1 Guest are viewing this topic. Read 46234 times.
There is no even air core inductors in this xover.
There are 4 I can see, although it seems strange they all share the same orientation, with two being stacked... I'm sure this is intentional but not sure why. Cored inductors are often better for woofers as the DCR can be much lower.
QuoteClinic, unorganic and dry sound I had ear fatigue in these short videos, but the hostess was nice legs. Irrelevant.
Irrelevant.I disagree. I think the hostess having nice legs is pretty relevant.
This make sense, even so is easily noted that some recordings are very good:https://www.youtube.com/watch?v=xlgdVmFf4n0&feature=endscreen&NR=1https://www.youtube.com/watch?v=w0TczwkYICQ
Have you all seen these videos on these new Yamaha ns 5000's...these speakers sound DAMN GOOD!youtube.com
The stop and go speed of these speakers are amazing!.. https://www.youtube.com/watch?v=CyIh2PnHKdc <
I design and build loudspeakers for fun, and am 100% positive I can build better sounding ones for less money.
I am curious how you came to this conclusion. Have you heard these?
I have compared my own homebuilt loudspeakers to the B&W 803 Diamond. Measurements are VERY similar, the sound is so close that it's not a matter of "better", but a matter of "preference". All for less than a third of the price of the 803 D.
The X-over filter in these NS 5000's is a prime example of doing things that are not visible to the audience the cheap way. Invest $200 (per cabinet) and they WILL sound better (if you know what you're doing that is).
If you were talking of a speaker other than the B&W 803 I'd be more impressed. Unfortunately I don't have much respect for the B&W line's sonics. If your homebuilt speaker compared favorably to the 42 year old Yamaha NS-1000, then you would have my attention...You seem once again to presume you know what you are doing and Yamaha does not—or is being deceitful in hiding inferior quality workmanship inside the box.I think you are over-reaching in your assumptions about the degree of care and knowledge that Yamaha puts into their crossovers. For example as early as 1972/3 they were working extensively with Nichicon, the manufacturers of the capacitors used in the NS-1000, at a time when most had yet to be awakened to the sonic differences between capacitors. As early as 1978, they were sufficiently concerned about the fine details in their crossover design that they were avoiding the use of solder in favor of plasma spot welding in the 1987 NS-10000. Does this sound like hiding inferior quality where it cannot be seen? Do you use solder in your crossovers?Then there is the small matter of the drivers themselves. They predated Focal in their use of beryllium for tweeters by—oh—35 years? 42 years ago they were employing 9 cm beryllium mid range domes, all of their own design and construction, of course, but probably not by one of the 'interns'. I'm not aware of any other beryllium mid range domes ever made by any company other than Yamaha for home use, and I don't think it's because they don't sound good, but more likely because they are beyond the capabilities of lesser companies and/or they are simply too costly to make. I am finally starting to see some beryllium being used in very expensive compression drivers, though.Read this and learn what a serious company you are trivially dissing:http://europe.yamaha.com/en/products/audio-visual/hifi-components/hifi-history/speaker/
Russell in the 70s there were lot's of other companies making good speakers,to me mentioning yamaha only means you know less than you think!welding and just caps don't make good speakers also
