0 Members and 1 Guest are viewing this topic. Read 18266 times.
Thanks for the heads-up/link.The review seems to try to provide a layman's explanation of the Multibit technology. Now I wonder if Multibit is a waste for Redbook (the vast majority of my music).Yggdrasil is a bit beyond what I want to spend, so am looking at the Gungnir or Gungbit-Multibit (dang those stupid names).
The Gumby will answer the mail!
How close is the Gumby to the Yggy?
SOLD!
That didn't take long... With all the love the Yggy has been receiving, just curious why it didn't work out for you or why the sale?
Not having heard the Yggy, (yeah you busted me) I can't answer that definitively; but I do own a Gumby. The conventional wisdom appears to be if $$ is a consideration (i.e. $2300 vs $1249), then buy the Gumby without hesitation; otherwise, buy the Yggy. The word from the folks at Headfi is that the Gumby will get you 80%-90% of the Yggy performance at 50% of the price. One poster who has heard and tested the Yggy, Gumby and Bimby made the following "terse and ribald" observations:1. Best of D-S Dacs - an indistinct sound is barely audible in the recording that appears to not be musically related to the orchestral piece playing2. Bifrost MB - someone in the Second Violin section has flatulated3. Gungnir MB - the flatulent sound originates with the 2nd chair in the 2nd row of the 2nd violins4. Yggdrasil - that 2nd chair, 2nd row, 2nd violinist has let loose with a Db when clearly the piece being played is in the key of G.According to Schiit Audio:"Gungnir Multibit brings a significant percentage of Yggy's performance to a price that's almost 50% less," said Mike Moffat, Co-Founder of Schiit Audio. "It uses the same time- and frequency-domain optimized digital filter algorithm running on an Analog Devices SHARC processor, similar medical/military-grade precision multibit DACs, and the same discrete JFET output buffers. We're proud of the fact that Gungnir Multibit costs $1249, as compared to Yggdrasil's $2299...." I think it's fair to say that the Gumby doesn't fall far from the Yggy tree. If I run across a more in depth comparison, I'll report it back.
Thanks for the info/opinion. Wondering using Redbook, how much difference there is between Gungnir and Gungnir-Multibit. I cheaped out on my last DAC because I only run Redbook (in a $5000 system without source). Schiit tells me that Multibit works for all PCM formats, but of course couldn't give me a definitive answer.
Semi related...BiFrost Multi-Bit versus Gungnir Multi-Bit via it's single ended outlets is very, very nearly a draw from what I've found. So it seems that Gungnir and Yggdrasil really are balanced designs at heart and should be considered/used as such.
