0 Members and 1 Guest are viewing this topic. Read 10772 times.
Two more thoughts. When the question about Shun alternatives comes up, the folks at knife forums often recommend Ryusen or Hattori HD. The reason for this is that they are much better versions of what Shun is doing: stainless damascus clad over a VG-10 core. You're getting a lot of recommendations for what are referred to as "laser" knives. Very thin, very light, single metal knives. This isnt surprising as they are the trendy item right now (before that, it was the powdered steel knives). I like them, but can feel a bit too precise and a bit fragile at times, and for a gift I'd prefer a more typical hand forged san mai for the added character. That said, you can slice crazy thin with the lasers. The Richmond and other AEB L knives fall in this category.
If you want something you can't buy at Bed, Bath and Beyond, you should buy a handmade, one of a kind knife from the guy who posted above me.His moniker tells it all. Bob
Now I don't want to go crazy here at all (I've seen some 'systems' that go for hundreds )
