0 Members and 1 Guest are viewing this topic. Read 10773 times.
I'm looking for a present for my wife, Japanese knives, preferably a small set of starter ones, price around $350.I read up on a few threads here, but I'm in over my head. I thought I found something in a Shun 3-piece Classic set for around $300. But then I found out you can buy them at bed, bath, and beyond. That just sucks out the exotic factor. Yes, I do count "exotic-ness" into it, please don't think less of me.The other problem I have is that a single brand has several different lines - so if someone says they like their Shun knives, do they mean Sora, Classic, Premiere? Is it better to go with the low end of a high end manufacturer or the high end of a lower end brand (same as in audio huh)?-david
Sorry, but I can't agree that Cutco knives are quality products. I've got a couple that I bought from some of my students over the years... they stay in the back of the drawer.
I was the one that recommended the Richmond AEB-L, but the Monster man makes very good points. These are very high quality, lightweight knives, but if heft is thought to be equal to quality they will not impress as a gift. Tojiro makes a good quality, hefty, set of VG-10 knives. Three knife sets are $150 under your budget, so add a nice nakiri if you do vegetables much.
Seriously, you have bought good knives, so don't skimp too much on sharpening. Rob will probably chime in here with definitive advice, but I'd say you want something that will at least sharpen to 4000 grit. I don't think that the double sided DMT nor your grand dad's Nortons are that fine. I still use my grand dad's razor stones at about 6000 grit when in a hurry, but it doesn't match what I can do with an Edgepro machine.
I have an EdgePro. Thankfully don't have the upgrade bug on it. Razor edge on all our knives.
What metal is it made from (which steel)?
