JVC RX-ES1sl PC
0 Members and 1 Guest are viewing this topic. Read 1441 times.
mcgsxr
JVC RX-ES1sl PC
« on: 15 Oct 2004, 03:58 pm »
Does this unit have a removable PC?  Cannot tell from the .pdf of the owners' manual.
If not, is it simply soldering surgery?
I would read through the 50+ pages on these units here, but at work...?
mark in Canada
  • Speakers....What Speakers ?
Re: JVC RX-ES1sl PC
« Reply #1 on: 15 Oct 2004, 04:06 pm »
Quote from: mcgsxr
mark in Canada
No removable power chord. If you want that....its DIY...or maybe Wayne (does nice work)....hey, try his binding post adaptor's(spring clips on JVC)....they work great!!! :)
ooheadsoo
JVC RX-ES1sl PC
« Reply #2 on: 15 Oct 2004, 04:17 pm »
Yup, it's really simple to DIY.  The existing cord just unplugs.  Then solder the new cord onto the remaining two pins.
mcgsxr
JVC RX-ES1sl PC
« Reply #3 on: 15 Oct 2004, 05:20 pm »
Yeah, Wayne is installing an IEC on my Teac, but I am trying to learn the basics...
IF I love this thing, then I will likely pony up for his work, I have had several pieces successfully modded by him for me.
Thanks for the tip ooheadsoo, I will check it out, when it arrives.
Mark in Canada
ooheadsoo
JVC RX-ES1sl PC
« Reply #4 on: 15 Oct 2004, 05:24 pm »
Well, the downside is that I didn't hear any improvment :P  Maybe my cord wasn't "high quality" enough ;)
mcgsxr
JVC RX-ES1sl PC
« Reply #5 on: 15 Oct 2004, 05:26 pm »
Well, that begs the question - what did you use?  I have a section of Belden 83802 and some cryo'd Hubbel hospital grade parts to build it out with.
I intend to use a section of this with my modded Teac, when it returns, and will have some extra, so I thought it might be pressed into service for the JVC, when it arrives.
mark in Canada
ooheadsoo
JVC RX-ES1sl PC
« Reply #6 on: 15 Oct 2004, 05:56 pm »
No audiophile cord for me :P  I used a hospital grade cord made by Quail.  14 ga., foil shielded, a ferrite choke on each end, terminated in a green dot certified plug.
