0 Members and 1 Guest are viewing this topic. Read 4168 times.
Again, I'm surprised at that SMPS and they are made for constant duty usually no turn off.$300 Vista Audio MKII I keep saying it because I'm sorry I sold mine.I picked up my Heed Quasar ($1200) with PS for $600.Many great used Phonos. Check US Audio Mart.There is a Parks Audio there with built in Cinmags used.There are also Musical Surrounding Nova's and Phonomena II's there.
I own an Emotiva and it hasn't had any problems.
In the mean time why don't you replace the stock power supply with another brand?I could and I started a thread asking for a good power supply. After much thinking, I decided to forgo the power supply and get a new preamp.The output voltage and current should be written on the supply. Get one with same voltage and at least as much current. If the connector doesn't match, cut off the old one and splice it on. That will give you a chance to do some research about a new one, or maybe you'll want to keep it.I see I've been preempted by Bacobits. I just got a Vista as a secondary phono and it's making mincemeat of 3 of my 4 phono stages. It has user selectable gain (40, 50, 55, 60, 65, and 70dB). Mine has custom loading for both resistance and capacitance. That's not the standard configuration, but you can have it made any way you want. I would characterize the sound as neutral. It's not lush, warm, bright or strident. It sounds like the record. If you're looking to impart a particular sound for your system, maybe a different unit would be better.That's why I'm asking about ss or tube. So far, I have not heard from any tube phono premp owners.neo
I own an Emotiva and it hasn't had any problems. AVA is Audio by Van Alstine. They are on the board and there is a link to the company. I have owned one of their preamps for years. Their stuff is no nonsense and delivers a quality of sound much higher than the price would lead you to expect. They also have upgrade paths available for much of their stuff.I've been in contact with Frank regarding his phono preamp. We'll see what happens.
If Emotiva had problems with PS's they would be failing all over. They would have to do something. I would think?AND it has not shown up on any boards. The Internet tells all. Ya can't hide.Lot of users on Audiokarma.
Your right. I favor SS. At one time I ran total 23 tubes throughout the system. Them days are over.Tube Phono's can be even more expensive to be as quiet as SS. Personal preference.Not familiar with the NAD never considered it. Always looked a little up the price ladder.
NeoGlad to see you finally ordered the Vista and like it. I still use my two everyday. I also had the XPS-1 and it was plugged for almost 2 years with no problems. It's back in the box now with one of the Vista's moving to the office since my new Modwright preamp has the tubed phono board. To 4Play unfortunately the combo of tubed phono stage and reasonably priced don't go together. The only one I am familiar with in the price category would be the Parks Audio but phono grade NOS tubes in the 6DJ8 family don't come cheap and most of the current production ones are strident. The Modwright uses tubes from the 12AU7 family which can still be found for reasonable prices. I think you would be hard pressed to find a better sounding and more flexible unit that the Vista for anywhere close in cost.
