AC Question
0 Members and 1 Guest are viewing this topic. Read 1195 times.
OBF
AC Question
« on: 14 Oct 2004, 02:58 pm »
Couple quick questions here:
Do you think audio gear would be more happy with 117 VAC or 112 VAC?
Would it be normal for a heat sink to be "hot", like 125 VAC between its surface and ground?
Thanks.
ctviggen
AC Question
« Reply #1 on: 14 Oct 2004, 07:06 pm »
It shouldn't make much of a difference, as most AC is turned to DC anyway.  I do not think that a heat sink should be hot (in the electrical sense).  There must be some short to the heat sink.
