AudioQuest JitterBug
0 Members and 1 Guest are viewing this topic. Read 9390 times.
Samurai7595
« on: 1 Oct 2015, 11:20 am »
Last night, I did some comparison listening for roughly 2 hours with my Bryston BDP-2 digital player.  My Bryston BDP-2 unit has the latest official software/firmware installed and the new/upgraded sound card (Integrated Audio Device [IAD]).
I connected my BDP-2 to my Devialet 200 via both AES/EBU & USB and switched back-and-forth between the two connections to compare sound quality.  This in no way was a very scientific experiment, just a personal experiment since I happened to be home alone yesterday evening & took advantage of the situation.  My AES/EBU cable is the Atlas Mavros digital cable ($485) and my USB cable is the AudioQuest Carbon ($170).
With these cables in place, I gave a slight edge to the AES/EBU connection.  It provided just a small amount of additional detail as compared to the USB connection which I expected given the price difference and built quality/material between the two.
However (to my surprise), when I introduced the AudioQuest JitterBug USB Data & Power Noise Filter ($50) to the AudioQuest Carbon USB cable, it was a different story.  With the introduction of the JitterBug, I could no longer hear a different between the two connections as the JitterBug provided a slightly quieter background allowing more detail to be heard.
This was my personal experience with my own equipment in my own living room.   However, when my wife came home, I repeated the tests for her and she came to the same conclusions I did.
So far, I'm really impressed with the AudioQuest JitterBug and wanted to pass this along (note: I have no affiliation with AudioQuest)!
Phil A
Re: AudioQuest JitterBug
« Reply #1 on: 1 Oct 2015, 02:17 pm »
I'm sure it made a nice difference.  I added an iFi USB Power Supply to my set-up and I thought I was crazy that I heard such a nice difference and I had a friend come over to confirm I wasn't crazy (or at least crazy with that conclusion :lol:)
Samurai7595
« Reply #2 on: 1 Oct 2015, 03:25 pm »
Nice!   :thumb:
jparkhur
« Reply #3 on: 1 Oct 2015, 03:51 pm »
I have an iFi Dac 2 with the iFi USB filter as well as two AQ Jitterbugs.  I have noticed similar changes for the better as stated above.  I noticed the biggest single change when either connecting the iFi or AQ piece.  I was extremely difficult to notice when I stacked them together.  I also put one in my usb3 hub, but have not been able to really sit down and A/B it.  I figured for 50 bucks, who cares.   I really like the iFi Dac 2, does wonders for my Mac Mini.
JP
Samurai7595
« Reply #4 on: 1 Oct 2015, 05:00 pm »
Good Stuff, so I'm not crazy either!   :D
jhm731
« Reply #5 on: 1 Oct 2015, 06:41 pm »
Samurai7595,
Can you turn off the 5VDC buss power on the your Bryston BDP-2's USB output?
The Devialet 200's USB input doesn't need to see the 5VDC buss power.
BrystonFan
« Reply #6 on: 1 Oct 2015, 11:48 pm »
Thanks guys.
I will give them a try.
Samurai7595
« Reply #7 on: 2 Oct 2015, 10:47 am »
Samurai7595,
I have no idea if and how this can be done on the BDP-2.
Anyone know?
Ned F. Kuehn
« Reply #8 on: 2 Oct 2015, 09:25 pm »
This little Bug cleans up grunge apparently from my external powered hard dive connected into my BDP-2 with IAD. I inserted it at the USB input to the BDP-2. I was rather taken back on the the improvement this Bug made! A lot of noise pollution seems to be injected into the USB from the power supply and what ever even in a lowly powered hard drive. Recommended  :D
Servingthemusic.com
« Reply #9 on: 3 Oct 2015, 12:01 am »
Anyone know?
Simply use the sBooster VBUS filter. It looks just like the AQ Jitterbug and it blocks the power from coming out of the bus as opposed to filtering it. $25.
https://www.sbooster.com/sbooster-tweaks/sbooster-vbus-isolator
I can tell you where to order it in the US. I bought 2.
Grit
  • - Garrett
« Reply #10 on: 3 Oct 2015, 04:37 am »
That makes great sense when you think about it. If you're just using the USB for signal, no need to possibly muddy it up with power.
Starchild
« Reply #11 on: 3 Oct 2015, 01:02 pm »
Ok, I'll bite.  Where did you buy it in the US?
Big Red Machine
« Reply #12 on: 3 Oct 2015, 01:06 pm »
Yes, inquiring minds want to know. 8)
Phil A
« Reply #13 on: 3 Oct 2015, 01:49 pm »
Their website lists a bunch of US dealers:
Authorized United States Distributors
Pro Audio Ltd
111 N South Dr
Tower Lakes, Il 60010
Tel: 847 526 1660
[email protected]
Source Systems, Ltd.
San Clemente, CA. 92672
www.sourcesystemsltd.com
[email protected]
Voice/Fax: 949-369-7729
Mobile: 949-322-4973
United States Resellers
    California
Audio Revelations
4733 Edinburgh Drive
Carlsbad, CA 92010
www.audiorevelation.com
[email protected]
(760) 434-2625
AudioVision S.F.
1603 Pine St. at Van Ness
San Francisco, CA. 94109
www.audiovisionsf.com
[email protected]
415-614-1118
Definition Audio Video Santa Monica
2934 Wilshire Blvd.
Santa Monica, CA 90403
www.definitionav.com
[email protected]
310-829-9888
Sound Decisions Audio
15732 Los Gatos Blvd
Los Gatos, CA. Zip 95032
www.sounddecisionsaudio.net
[email protected]
408-449-6774
    Colorado
TweekGeek, Inc.
7075 Umber Court
Arvada, Colorado 80007
www.tweekgeek.com
[email protected]
303-653-6341
    Florida
Audio Vision South
3655-Henderson Blvd.
Tampa, FL 33609
813-871-2989
[email protected]
Contact: George Liu
Suncoast Audio, LLC.
Baradenton, FL. 34202
www.suncoastaudio.com
941-932-0282
941-727-6646
    Illinois
Audio Archon
1500 S. Lancaster Lane
Libertyville, Illinois 60048
www.audioarchon.com
[email protected]
847-687-4800
    Indiana
Tone Studio
623 E North St,
Indianapolis, IN 46204
Phone:(317) 423-3050
    Kansas
Acoustic Sounds, Inc.
P.O. Box 1905
605 W. North St.
Salina, KS, 67402-1905
Questions: 1-785-825-8609
Fax: 1-785-825-0156
www.store.acousticsounds.com
    Minnesota
Audio Perfection
7401-Lyndale Av. S.
Minneapolis, Mn. 55423
612-866-0083
[email protected]
Contact: Mark Balkowitch
    Nebraska
The Sound Environment
Rockbrook Village Shopping Center
11021 Elm St,
Omaha, NE 68144
Gale: 402-610-2379
Todd: 402-306-4762
Showroom: 402-391-3842
 www.soundenvironment.com
    New Jersey
Audio Doctor
112 Sherman Place
Jersey City, N. J. 07307
www.audiodoctor.com
[email protected]
877-428-2873 FREE
    New York
Earsnova
3 E 28th St
New York, NY 10016
Tel: +1 212-288-2855
Email: [email protected]
Website: www.earsnova.com
Ciamara
71 Nassau St #15c
New York, NY. 10038
www.ciamara.com/lumin
1-844-242-6272
    North Carolina
Night & Day Audio
Durham, NC 27713
www.nightanddayaudio.com
[email protected]
(919) 632 – 2569
    Texas
Design Audio Video Inc.
15240 Northwest Road
 Whitehouse, Texas 75791
www.designaudiovideoinc.com
[email protected]
(903) 571-7189
    Virginia
Command Performance AV
7105 Marbury Court
Falls Church, Virginia. 22046
www.commandav.com
[email protected]
703-532-7239
866-713-3006
Servingthemusic.com
« Reply #14 on: 3 Oct 2015, 02:21 pm »
Contact Brian Tucker @ Pro Audio. Phil posted contact info below.
I paid by Pay Pal and got them two days later USPS.
Servingthemusic.com
« Reply #15 on: 3 Oct 2015, 02:23 pm »
yes indeed. If your DAC does not need the 5V for the handshake, why even pass through the power?
Phil A
« Reply #16 on: 3 Oct 2015, 03:19 pm »
That's true - I should do that with my Teac UD-501 in the secondary system as the power is on the chip in the DAC.
Starchild
« Reply #17 on: 3 Oct 2015, 03:56 pm »
That's why I bought a data only usb cable.  However, based on what I've read, such a device could still offer an improvement.  I sent an e-mail to Uptone to ask about how the Regen works with a data only cable.  I'll let you know what they say.  But I'm willing to venture $25 to try the sBooster VBUS filter.
Servingthemusic.com
« Reply #18 on: 3 Oct 2015, 04:00 pm »
yes, please report back about the REGEN. Although it may have more to do with your DAC.
But...interestingly..the new iFI USB 3.0 does NOT work with the sBooster, where the previous iUSB did.
Starchild
« Reply #19 on: 3 Oct 2015, 04:44 pm »
I'm using a Bryston Buc-1 usb converter with my YSF data only usb.  My old dac died and I'm limping along on an old Musical Fidelity X-Dac while I'm sorting through the market place.  The old x-dac actually sounds pretty good.
