0 Members and 1 Guest are viewing this topic. Read 4933 times.
I'm surprised nobody recommends a Musical Paradise MP-301 MKIII. With upgraded tubes is about $400. Great amp! Highly recommended! I replaced the EL34's and sounds great! Check it out!Dan
Hi,...I know this ha been probably asked before but I have a Decware pre amp and am currently using a Crown 1500 as an amp. Although I am quite happy with this setup, what alternatives are there to replace the Crown that would be worth the investment. Budget would be $1000 area......FYI I need to have the Crown volume set at 3 PM and pre amp about three quarters of the way up to get decent volume. It gets a bit noisy (humming,buzzing) with both having to be set so high.
You must have the line level output controls turned down on the CSP3.
I see the output voltage is adjustable on the CSP3 from 0-30V. 30V!I'd set it at 1.5V or 2V output.
Is the ZDAC set to fixed output or variable?
