Amplifier for alnico super 6
0 Members and 1 Guest are viewing this topic. Read 4934 times.
mcgsxr
Re: Amplifier for alnico super 6
« Reply #20 on: 28 Sep 2015, 11:56 am »
Odd for sure.
I use a Crown XLS 1500.  Driven directly from my DAC via RCA's (figure on 2v output at max volume on the DAC), I have the gain pots set at 2pm.  I use banana plugs, but my speaker outputs were replaced with Pomono posts on the amp.
With my 85db Maggies I cannot max the digital volume on my DAC or it gets way too loud.
Switching to my Nuforce preamp, using the XLR inputs - gain maxed on DAC, gain at 2pm on Crown, same use of banana's for speaker connection - I cannot put my Nuforce volume past 75-80 of 100 or it gets way too loud.
Using significantly higher sensitivity speakers, you should have plenty of power for sure.
sugbob21
« Reply #21 on: 13 Oct 2015, 02:08 pm »
My new toy !
Check out the Fleawatt. A sweet sounding amp with my Alnico,s ! Check out Derek,s blog and take a look at his work ....exceptional !
