0 Members and 1 Guest are viewing this topic. Read 4835 times.
Several years back, Gary Dodd took a couple of my old Eico mono integrated amps, keep the iron, and basically threw everything else out, and made a magical pair of little mono integrated amps for my bedroom. Very wife friendly, just turn it on and dial in the two volume knobs to your liking. Earlier this spring, I asked Gary if I could clone these amps for my daughter and got his blessing. I felt quite confident, having cloned a Dodd design with my physics classes, and this was a simpler design. I put off the project for a couple of months, and in the meantime we lost Gary... and of course, now I need some help.I built one of the amps over the past couple of weeks. Gone back over it several times, caught several errors, redid things, and got it playing music. But the distortion is bad, really bad. I suspect that a source might the resistors I've used. Before I started, I took it to a local shop (not an ethical group but the only one in town) and was told the original resistor were 1/2 watt. I ordered a box of 400 resistors for just over ten bucks that covered most of the values, but they are only half the size of the ones that Gary used. His were blue, 3mm thick, and mostly 1% tolerance. The box of resistors were tan, 2mm thick, and mostly %5 tolerance. Is this the likely problem? Also, with various resistors to choose from, metal, carbon, ??? what should I use? Without my buddy Gary, I could use some advice. This is a two 6qb5, 6ca4, and two 6dj8 design with an output transformer, and power transformer, and a choke. The output is about 14W. Do I start over with better resistors from Mouser or Digikey?Scott
Thanks guys. That helps a bit. I read over on DIYAudio that the brown/tan resistors are carbon and the blue are metal. Can anyone confirm that and does it matter?
yes that's right,but i dont think it's a standard,also metal film usaually have 1% tol and carbon 5% tol,does it matter,not my experience,what is important is the power rating and value.cheers...
Always trust a properly designed and calibrated multimeter!
Hmmm, I may have to look into getting something other than my Harbor Freight VOM. Is there a decent meter for under $50? Under $100?
