SUT failure
0 Members and 1 Guest are viewing this topic. Read 1163 times.
SteveRB
SUT failure
« on: 15 Sep 2015, 10:44 pm »
All,
I have an older Denon AU-250 SUT. A couple years ago, after a move, the unit stopped working. I didn't have a chance to look at it closely. But i did check all the wring points for connectivity, and that was not the issue.
I kinda though the transformers themselves were built for life. Is there any way of checking the them with some home (non specialized) tools?
mgsboedmisodpc2
Re: SUT failure
« Reply #1 on: 15 Sep 2015, 11:51 pm »
try the Denon  AU-300LC or Fidelity Research FRT-3G
SteveRB
Re: SUT failure
« Reply #2 on: 16 Sep 2015, 12:04 am »
Thanks.
BUT this post was me fishing for repair advice prior to replacement.
BUT BUT do you have experience with the two you suggested?
BobRex
Re: SUT failure
« Reply #3 on: 16 Sep 2015, 12:10 am »
The problem with a transformer is there isn't a whole lot that can be checked.  Take an ohm meter and check continuity between + and - on the same jack, check all 4 jacks. That's about it.
neobop
  • BIRD LIVES
Re: SUT failure
« Reply #4 on: 17 Sep 2015, 10:25 am »
Transformers are passive devices. It's really nothing but two coils with iron cores, for each channel.  After a move something must be messed up inside?
Can you open it?
neeo
neo
« Last Edit: 17 Sep 2015, 11:56 am by neobop »
SteveRB
Re: SUT failure
« Reply #5 on: 17 Sep 2015, 04:11 pm »
yeah,
I opened it. checked all the connections and the continuity. Seemed ok. But no sound...
...so just dropped a bundle on a Cinemag Step-up.
WOOT.
