0 Members and 1 Guest are viewing this topic. Read 19532 times.
Arguably the most basic thing a speaker has to get right is the tonal balance, but because tonal balance is very much a room-interaction thing (since most of what we hear is reflected energy), right off the bat we're swimming in the "deep end" if we dive into the question of which sonic attributes matter the most. So what looks like a tangent is just going deep into one of the basics, in my opinion anyway.
I just have to say, I couldn't disagree with this more.
IMO tonal balance is determined primarily by the first impulse, as is the majority of how we perceive a speakers sound. When I take speakers (and we make models with very well controlled and even off-axis response) between my 3 different rooms, the overwhelming characteristics of how they sound remain intact. What changes in how well they image and disappear into the room.
Inside the speaker box the back of the cone produces exactly the same music the front of the cone does,it is like a speaker in a room ,think the room as a speaker box, then you'll see my point...
3) Which one is more important to achieve, question 1 [pattern matching in the crossover region] or question 2 [overall controlled directivity]?
4) How low of a frequency should one aim in controlling directivity? 1khz? 500Hz? 250Hz?
5) How important is a flat DI versus a smoothly rising DI (from say 1khz to 20khz) as long as the DI is at least 6dB?
6) Relative to controlling directivity in the horizontal axis, how important is it to control directivity in the vertical axis?
7) How does all of the above impact room treatment at the 1st reflection points on the side wall, ceiling, floor, and front wall? What real world experience have you had (irrespective of measurements)? How does this affect image specificity vs sound staging and spaciousness?
The Princeton study shows many graphs and oblique numbers but offers no conclusions, it only serves to muddy the waters for me, especially since one of the lowest scoring speakers is one I own (previous version) and love.
So Duke, with all this controlled directivity and ambience/reverberant field discussion, can you describe in your opinion what the ideal directivity would be?
George are refering to the acoustic negative back side driver cone sound emissions.The front driver sound emissions from the cone are in positive acoustic phase and negative at the back side of the driver.On boxed lousdspeakers the back emissions are not utilized as music in the room, but they are muffled by the box.Seems was this george was try to say.
Another nasty unspoken secret about speaker cabinets. Keep in mind that while many manufacturer's gloat about how inert their cabinets are, the driver cone is extremely lightweight and is probably 1,000 times more acoustically transparent while the sound pressures inside the cabinet vastly exceed those we hear on the outside. At the same time dipole/open baffle builders gleefully support the concept that we should hear this out of phase sound. The key would be to keep the back-wave from reflecting back towards the driver. Various materials/designs are used to reduce reflection have been introduced but perhaps the best is to slope the back wall relative to the front baffle as can be seen in pipes and transmission line speakers.
Several decades ago Ken Kantor designed a speaker system for Acoustic Research that did just about everything I'm talking about here. It was called the "Magic Speaker". It was a commercial failure and I never got to hear a pair, but I think he was aiming at pretty much the same goal posts that I am. There's some good information in the brochure pages at the link.
At the same time dipole/open baffle builders gleefully support the concept that we should hear this out of phase sound.Most or all musical instruments emit phase - and + in various patterns and different intensities.Phase - arent out of phase, its the half pair from the recording event, not - and + phases are need to for a real, natural soundstahe.The key would be to keep the back-wave from reflecting back towards the driver.If it was true sealed box would be the best enclousure.Dipole and OB use the neg sound phase to made the a 3D and bigger sound stage than monopole speakers.Monopole speakers have the soundstage and instrumental image harmonically poor, they lack 50% of the sound to complete the real musical event.Unfortunately Dipoles and OB speakers lost 4 to 5dB at sensitivity in attenuation by use both sound phases.
Toole/Harmon's preference testing indicates an extremely strong preference for speakers with smooth off axis response, but also for the presence of 1st reflections which is an area I don't necessarily agree with.
