0 Members and 1 Guest are viewing this topic. Read 31150 times.
The Kappa 9 had 2 - 12" woofers. Here's a nice shot of the Kappa 9:Sorry, that girl got in the way of the giant amp.neo
The best speakers I've heard do happen to be conventional mid-efficiency speakers, TAD Ref 1s, but they are $90k and are optimally paired with another $250k worth of TAD electronics. Not exactly cheap...I think the term "reference" is used way too much in the audiophile world... ad nauseam. Such a relative term. I would hope speakers at $90K and then add 2.5 X's that...would be best in class. Certainly hope so. I wish I was there though.
Over the years, it seems that the majority of the speakers considered as "reference" are of low to moderately low efficiency? This is one of the major factors that drive audiophiles to higher power amps. These high end speakers need more watts to perform at there best. So, wanted to start a discussion as to the factors that drive this issue. It does seem pretty challenging to make a high efficiency speaker that performs as well as many of the better low efficiency models.
I think reference as the AER MD3B or Feastrex Alnico.
In an way... I actually have a set of MD3 coming my way, the speaker I'm putting together might feature them. But my previous comments on single drivers still apply... less so to the AER as it's FR is abnormally flat but all the other things. A friend has Lamhorns with AERs and it definitely has less compromise vs any other single driver I've ever heard.BRM, it's relative... the MD3 I'm getting are 106 dB.
A great article about the term "reference" speakers by Alan Lofft.http://www.axiomaudio.com/reference
When you say Reference I think of the large Focals and Wilsons that are like 93 db efficient at $100k+. So I think of ref speakers as being efficient, not inefficient.
So what are the qualifying specs for high vs. low sensitivity, over and under 90db?
I don't understand why more reference level speakers don't have self-powered bass sections. Then you main amp only has to power the mids/highs, which is a much easier task.
Most self-powered bass sections on speakers use cheap plate amps that don't sound good. I'd love for someone to list a couple of "reference quality" plate amps. Perhaps a better solution would be a bi-ampable reference speaker. Although I'm not sure the cost/benefit would work in this scenario.
