0 Members and 1 Guest are viewing this topic. Read 31147 times.
...and there can be sonic downsides to putting a lot of wattage into a speaker.
Duke --Can you elaborate on this ["there can be sonic downsides to putting a lot of wattage into a speaker"] "? I'm in the process of procuring a 98dB speaker and I have a 300wpc SS amp that I hadn't planned on replacing, so that's why I'm asking. I never play music loudly if that matters at all.
isn't that the same thing???...
Hello Duke, Thermal compression is not really an issue with woofers in a domestic listening environment where RMS power sometimes barely exceeds 1 watt, 2-3 watts RMS is typically considered high and 10 watts rms is alot , most of the amplification is usually necessary for dynamic peaks ...In Recording Studios and pro sound applications , yes , as you pointed out with Toole ... Regards
Have you ever measured for Dynamic compression ... ?
It's amazing just how distorted the term "reference" has become. And it has absolutely nothing to do with sensitivity. Look how many reviewers who are out there reviewing electronics on speakers that are not reference even though they call them reference. And yes they are some of the big name manufacturers. You can't trust an amp review from a reviewer who's "reference speakers" measure like crap. I don't even think the reviewers know what a reference speaker is.
No, I haven't. I usually use prosound drivers that are unlikely to see more than 10% of their AES rated power on peaks, and when that's not feasible, I use multiple drivers. If you've ever heard a speaker that needs to be turned up to "come to life", you may have heard one of the consequences of dissimilar power compression characteristics among drivers. The "come to life" level may be where the relative loudness of the different drivers is correctly balanced, and at significantly higher or lower levels the tonal balance may be wrong. One advantage of high efficiency and/or high thermal capacity drivers is, their thermal characteristics are less likely to diverge at levels normally encountered in home audio, so their tonal balance stays the same across a wider range of volume levels. As a result, high efficiency speakers and high-thermal-capacity low to medium efficiency speakers usually still "come to life" at low volume levels. As an example of this issue, suppose we were tasked with "voicing" the speaker Toole describes above. Let's say we wanted it to sound great at 90 dB so that it would impress people in a fairly loud demo. So we voice the speaker to be "flat" at 90 dB, where the midrange driver is compressing by 4 dB more than the woofer and tweeter. So down at 70 dB, the bass and treble would be 4 dB softer than the midrange, probably rendering the speaker boring and lifeless. At still lower levels, if anything the discrepancy would be even worse. This points to an advantage of single-driver speakers - their tonal balance usually changes little as a result of thermal compression or thermal modulation (the short-time-constant effect Toole was talking about).
