Audio/Video Gear and Systems
Planar Circle
SteveFord
Maggies with Aragon amp?
0 Members and 1 Guest are viewing this topic. Read 3313 times.
kylevuong19
15 Aug 2015, 06:33 am »
Hi guys,
I'm just wondering if any of you guys have try the matchup Aragon Amps - Maggies and can give some opinions based on this matchup?
http://www.aragonav.com/8008-mkii-klipsch
400 watts to 4ohms high current should be enough to drive the 1.7 Maggies?
jk@home
Re: Maggies with Aragon amp?
15 Aug 2015, 10:43 am »
I used to use an old pre-Klipsch 8008 with a pair of MMGs, did great. Still using the amp today. Don't know anything about the new ones, except that they are double the price of the old.
SteveFord
Facilitator
Reply #2 on:
15 Aug 2015, 02:38 pm »
That's plenty of power but I've never heard them so can't comment on the sound quality.
jimbones
Reply #3 on:
17 Aug 2015, 03:37 am »
aragon has a ton of power and current capability. i owned one for many years and loved it. Good for power hungry speakers and the best bass (150 and down) of any amp I've owned.
ajzepp
Reply #4 on:
18 Aug 2015, 07:36 pm »
The first time I ever heard the 3.6s was on an Aragon amp at a Maggie dealer in Alpharetta, GA. Sounded really good to my ears.
bisP
Reply #5 on:
18 Aug 2015, 08:46 pm »
Used the DIA-100 integrated with MMGs for a few months. Enough power for a small room. Treble was bit hard which DIA-100 is known for. But felt more power could do better, which was indeed the case, as found after moving to Emotiva XPA-2.
kylevuong19
Reply #6 on:
19 Aug 2015, 03:58 am »
Thanks guys for your input. I find that Maggies already have a lot of treble so a "warm" sound amp will not make the high notes too harsh. I really want to try the Maggies with Aragon. For its price and its power I think it's a decent one.. Also the Aragon is Class A/B amp, according to Magnepan website it should work best...
JerryM
Where's The Bar?
Reply #7 on:
19 Aug 2015, 04:35 am »
Boy, for that kind of money to drive Maggies I sure would consider the AVA 600R...
twitch54
Happy Listening.....Dave
Reply #8 on:
19 Aug 2015, 03:13 pm »
I used the 8008 for years on my 3.6's ………….it's still providing great service to this day in my sons set up.
Highly recommended !
Last Edit: 19 Aug 2015, 06:31 pm by twitch54
rollo
Restricted
Rollo Audio Consulting -
Reply #9 on:
19 Aug 2015, 05:55 pm »
For me the most natural and dynamic sound from Maggies was either the Audio Research DR250mk2 servo or older Conrad Johnson amp. Just cannot remember the model. When I do i will post it. Next up was a hybrid class "D" amp with Reflector 6H30 input tubes offering 40 amps of current and a tubed preamp.
If you Bi-amp the Maggies the Arragon is a great bass amp. A Hi-Fi sound on top. If you insist on the Arragon gat a lush sounding tubed preamp.
charles
Planar Circle
SteveFord
