BDP-2; Best port to plug in external usb drive
0 Members and 1 Guest are viewing this topic. Read 1526 times.
lateboomer
« on: 27 Jul 2015, 07:11 pm »
I am BDP-2 owner and would like your advice that which usb port is the most ideal one to plug in external usb hard drive for music files? And which port is best to output usb audio to BDA-2?
I heard that general rule is not to share usb input music files with USB audio to prevent interference, instead should use FireWire connection for music files input to avoid crashing with USB audio.
Or I should use eSata port for music files external drive input instead?
unincognito
    • bryston.com
Re: BDP-2; Best port to plug in external usb drive
« Reply #1 on: 27 Jul 2015, 09:35 pm »
That doesn't really apply to the BDA or most USB Dac's for that matter.
lateboomer
« Reply #2 on: 27 Jul 2015, 11:51 pm »
May I know which usb port of digital player BDP-2 that is the most ideal one to plug in the 2.5" external hard drive which stores music files?
It is because in front of BDP-2 have got 2 usb ports and at the back there are 4 usb ports. I am not sure which one I should plug the external hard drive in.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 28 Jul 2015, 12:23 am »
Hi
It really does not matter but most people use the rear ports for their hard-drive and the front ports for their thumb-drives.
james
srb
« Reply #4 on: 28 Jul 2015, 01:03 am »
Typo FYI:
In the Bryston BDP-2 Owner's Manual on page 5 it correctly states that each USB port is limited to 500mA, but previously on page 4 it says that each USB port is limited to 50mA.
« Reply #5 on: 28 Jul 2015, 01:29 am »
Typo FYI:
Thanks Steve
james
