0 Members and 1 Guest are viewing this topic. Read 7476 times.
here is an option to consider ...Buy a Schiit Audio Magni 2 headamp & Modi2 dac for $99 each: http://schiit.com/products/magni-2Apply remaining $300 to a good used pair of headphones that suit your tastes. That would be an excellent entry system on a tight $500 budget. Upgrade amp & dac later if you so desire.
Edit: here is an option to consider ...Buy a Schiit Audio Magni 2 headamp & Modi2 dac for $99 each: http://schiit.com/products/magni-2Apply remaining $300 to a good used pair of headphones that suit your tastes. That would be an excellent entry system on a tight $500 budget. Upgrade amp & dac later if you so desire.
I just noticed the HIFiMan HE-400 Headphones right now on Amazon for $249.00 Might be something to look into if your interested. I would love to give these a try myself..http://www.amazon.com/gp/product/B007ZG32I4?psc=1&redirect=true&ref_=ox_sc_sfl_title_5&smid=AQG144I0DN37H
This. I recently bought a pair that unfortunately had a driver fail. Hifiman was more than happy to fix it under warranty though. The problem was that I thought I was being smart by sending them a few extra bucks in order to move up to the newer HE-400i...that was a big mistake. The HE-400 is a better headphone...the trick is that you really should get the velour pads that are offered as an option. The pleather pads that come stock don't allow you to hear this phone for what it really is. Being that you fancy electrostats (at least I think you do!), I think you'd really like these.
