0 Members and 1 Guest are viewing this topic. Read 6858 times.
this looks like an advertisement to me, not a question
Well, you are not drooling over Salk or AVA, so perhaps he's upset?
Curiously, just last night I dropped in on a friend who showed off his mono cartridge and setup.
Peter at Soundsmith modifies Denon 103 carts to mono. They sound very good, too, if you like the 103's sound. I agree that a more advanced stylus benefits more recent mono LP reissues. Audio Technica has a couple of mono cartridges that fit your budget, but I haven't heard those.
Wouldn't it be cheaper to just buy the Denon 102 at $250?
The 102 also has a relatively limited frequency response, compared to most mono-dedicated cartridges, which tend to utilize frequencies from 20,000 hz - and 20,000 or 25,000 khz. The Denon 102 covers a freq response of only 50 hz - 10 kHz.
A user would still be dealing with the hookup issues, unless the OP is wanting to just use a single channel for playback (which he may). If he is wanting a cart mainly to play modern mono reissues like the Beatles mono vinyl box (a really great reissue set!) or the Dylan mono box on a 2-channel rig, a better bet is likely a dual-coil contemporary mono cartridge with greater frequency range and a more advanced stylus, IMO.That first Audio-Technica mono is inexpensive enough that I might buy one to try out.
