On Record Cleaning
0 Members and 1 Guest are viewing this topic. Read 1263 times.
Speedskater
  • Kevin
On Record Cleaning
« on: 23 Jun 2015, 04:01 pm »
I just saw this thread:
vinyl coefficient of friction
http://www.diyaudio.com/forums/analogue-source/276155-vinyl-coefficient-friction.html#post4366962
Note that 'SY' is both a plastic's expert and a tube phono pre-amp designer.
GentleBender
Re: On Record Cleaning
« Reply #1 on: 23 Jun 2015, 04:20 pm »
Very interesting. I have yet to do more than protect my vinyl and use a brush before play.
SteveRB
« Reply #2 on: 23 Jun 2015, 04:57 pm »
Interesting...
by this logic the best method would be a gentle cleaning of a batch of records and allowing them to sit for a day or so prior to playing them.
"...if you remove the plasticizer from the surface, more will bloom back over a few hours or so. If you play the record immediately, the damage will unfortunately be permanent.
The goal of washing should be to only remove external contaminants, and there's some very good ways to do that- I'm sure many have been commercialized. I use distilled/deionized water with a tiny bit of a proprietary surfactant...
Devil Doc
  • On the road to Perdition
« Reply #3 on: 23 Jun 2015, 05:14 pm »
I kind of like this thread. http://forums.stevehoffman.tv/threads/a-very-long-primer-on-record-cleaning-fluids.58986/ It addresses just about all of it and you don't have to be a chemical engineer to understand it.
Doc
Speedskater
  • Kevin
« Reply #4 on: 23 Jun 2015, 07:29 pm »
Doc
I would say that you need to be much more a chemical engineer to understand it!
The main part of that thread is now some 10 years old and has a very different view-point than that of 'SY'.
