BDP-2 - New Bryston Integrated Audio Device
0 Members and 1 Guest are viewing this topic. Read 57367 times.
Norton
Re: BDP-2 - New Bryston Integrated Audio Device
« Reply #100 on: 17 Aug 2015, 05:59 pm »
Hi Norton
Glad you are enjoying it - Stereophile is doing a follow up review on it as well and so far my sneak peak indicates a winner  :thumb:
james
PS - sorry what is a Hugo?
James, I'll give you the benefit of the doubt that you are not "pulling my leg" as we say in the UK over that last comment.  The Hugo is Chord's very well reviewed DAC/Pre/Head amp which has had wall to wall publicity here. I bought it to replace the DAC64 I've had for 11years, and pretty much agree with all the +ve reviews, but after upgrading to the IAD, I've gone back to the DAC64 as it sounds so good now over AES.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #101 on: 17 Aug 2015, 06:05 pm »
Yes I was being flippant ! I really like the AES as well with the new card
James
R. Daneel
« Reply #102 on: 17 Aug 2015, 06:38 pm »
Hi Norton
james
Hi James!
When the review becomes available, perhaps you could share it with us? I am interested to read what they have to say, especially if they conduced some measurements.
Cheers!
Antun
dgarratt
« Reply #103 on: 18 Aug 2015, 12:09 pm »
Hi Guys,
I've installed the IAD in my BDP2 and while I haven't done any extensive testing it seems to be working well. I've upgraded the BDP to the latest firmware but I do not see the card listed under audio devices as described in the final steps in the instructions. Is this normal?
« Reply #104 on: 18 Aug 2015, 12:14 pm »
Hi Guys,
Hi
If you are getting sound through the AES or COAX then the new card is working.  It should look like this in Audio Devices.
dgarratt
« Reply #105 on: 18 Aug 2015, 12:37 pm »
Hi
Hi James,
Thanks for getting back to me. Mine doesn't list any devices on that screen at all but does seem to work none the less. I'm wondering if it's just an issue with the way the web interface is being rendered within Safari on my mac.
Probably a question for Chris...is a way I can check if it's been detected correctly within the terminal console?
unincognito
    • bryston.com
« Reply #106 on: 18 Aug 2015, 08:09 pm »
Well it is likley the page isn't renderin correctly for what ever reason, but it has been tested with safari on a Mac.  Are you running atleast firmware S2.14?  And what version of Mac OS X is on your Mac?
dgarratt
« Reply #107 on: 18 Aug 2015, 08:57 pm »
Hi Chris,
I'm running the latest version of MM, I think it's S2.16 with MacOS 10.10.5. I'll try another browser to see if that makes a difference and get back to you.
« Reply #108 on: 19 Aug 2015, 11:41 am »
Hi,
I am Peter from Malaysia.
I received the new Bryston integrated audio card the next day after I paid online.
Thank you for superb service.
The new Bryston card really brings the BDP-2 digital player to another level. I would say night and day difference. The sound is more musical and analog, less digital sounding.
We are impressed and super happy. :)
Peter Cheeng
dgarratt
« Reply #109 on: 19 Aug 2015, 12:11 pm »
Hi Chris,
I tried Chrome on a Windows PC and got the same result (see screenshot below).
I did however find the following within the MPD logs:
[ 2.037070] usb 1-2: New USB device found, idVendor=1db5, idProduct=0002
[ 2.037153] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.037229] usb 1-2: Product: Bryston BDP Audio Device
[ 2.037297] usb 1-2: Manufacturer: Bryston BDP
[ 2.037362] usb 1-2: SerialNumber: 999999
Is this the IAD?
unincognito
    • bryston.com
« Reply #110 on: 20 Aug 2015, 12:29 am »
Hi Chris,
Is this the IAD?
If you place it in service mode and email me the service id i can take a look
dgarratt
« Reply #111 on: 20 Aug 2015, 02:44 am »
Thanks Chris, email sent.
R. Daneel
« Reply #112 on: 22 Aug 2015, 12:43 pm »
Could someone post a close-up photo of the BUC board?
« Reply #113 on: 22 Aug 2015, 02:16 pm »
Hi
There is a shot of it in the first post on this thread.
james
alexone
« Reply #114 on: 22 Aug 2015, 08:15 pm »
Hi
james
James,
i believe he wants some pics of the BUC and not the BDP?!?
al.
lateboomer
« Reply #115 on: 26 Aug 2015, 05:05 am »
I am that Peter guy from Malaysia. Since adding the new card improves spdif/AES outputs so much better than usb audio output, I got a silly question to ask. Is there a way to upgrade usb to use dedicated audiophile usb card with BDP-2 like the SOTM usb card to seperate its power supply and interference  from motherboard. This will also entice more people to shift to BDP from computer related server like CAPS.
« Reply #116 on: 26 Aug 2015, 10:19 am »
Hi
You could use the BUC-1
james
R. Daneel
« Reply #117 on: 26 Aug 2015, 03:59 pm »
James,
al.
Oh no, I was just hoping to see a larger picture of the BUC board inside the BDP-2 so that ICs used would be visible.
BrystPlug
« Reply #118 on: 2 Sep 2015, 12:28 pm »
I know it's not the best thread to ask but... Is there a big improvement using AES instead of BNC on the BDP-2 ?
unincognito
    • bryston.com
« Reply #119 on: 2 Sep 2015, 07:50 pm »
I think its more of a preference thing, some people seem to like one over the other and they have there reasons.
