BDP-2 - New Bryston Integrated Audio Device
0 Members and 1 Guest are viewing this topic. Read 57360 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 22 Jun 2015, 01:52 pm »
Bryston BDP-2 soundcard upgrade Bryston Audio Device replacing Juli brought significant improvements in the sound - image density, lower noisefloor, good overall bandwidth reproduction including an excellent low frequency delineation, very stable dynamic swing that gives equally stable & palpable soundstaging!
Superb job by Bryston!!
Joseph Ki Cheong Ming
Old Card
New Bryston Card
« Last Edit: 2 Aug 2015, 12:56 pm by James Tanner »
bjski
Re: BDP-2 - New Bryston Integrated Audio Divice
« Reply #1 on: 23 Jun 2015, 12:23 am »
Getting ready to install mine.
« Reply #2 on: 23 Jun 2015, 12:29 am »
Awaiting your thoughts.
R. Daneel
« Reply #3 on: 23 Jun 2015, 03:28 pm »
Hi James!
How come you're upgrading the internal sound-card? From my understanding, the existing card is an ESI Juli@ which means it uses a VIA Envy24 chipset and as such, it a superb piece of audio hardware. I remember a Stereophile review from years back when Juli@ was stated to have the cleanest S/PDIF square-wave trace on the oscilloscope.
Can you please shed some light on this?
Cheers!
Antun
R. Daneel
« Reply #4 on: 23 Jun 2015, 04:35 pm »
One other thing - the website states all new BDP-2 players will be equipped with the new device. My question is - can the same upgrade be done to the BDP-1 (the original one with conventional XLR and BNC digital outputs)?
Cheers!
Antun
« Reply #5 on: 23 Jun 2015, 04:45 pm »
Cheers!
Antun
Hi Antun
No sorry the BDP-1 will not take the new Bryston integrated audio device only the BDP-2.
james
« Reply #6 on: 23 Jun 2015, 04:47 pm »
Hi James!
Cheers!
Antun
SUBJECT: Announcing Bryston Integrated Audio Device Card
May, 2015
Hi Folks,
We have been working on a Bryston proprietary “Integrated Audio Device” card with much improved specifications to replace the current two-piece ‘Soundcard’ and ‘SPDIF interface module’ (AES/BNC) utilized in our current BDP-2 Digital Player.
I am happy to report that an all new integrated version of the BDP-2 audio card is now going into production and should be available in a few weeks from now.
All BDP-2’s currently on order will be fitted with the new Bryston integrated audio card.
BENEFITS:
•   No reliance on the quality level of third party products or having to modify said products
•   Improve the performance by hand selecting and testing all the components in house
•   Eliminates 3 connection points
•   Integrates the output module and the sound processing section into one circuit instead of two.
•   The Bryston audio device is directly powered by the high quality linear power supply rather than the motherboard.
 Any current BDP-2 owners may have their units upgraded if desired.
Bryston
R. Daneel
« Reply #7 on: 23 Jun 2015, 04:53 pm »
Edited.
R. Daneel
« Reply #8 on: 23 Jun 2015, 04:55 pm »
Hi Antun
james
Are there mechanical or electrical reasons for that? Or both?
Cheers!
Antun
« Reply #9 on: 23 Jun 2015, 04:59 pm »
Cheers!
Antun
Hi Antun
A number of issues -  mechanically will not fit , electrical connectivity issue and a power issue to drive the new board.
james
R. Daneel
« Reply #10 on: 23 Jun 2015, 05:04 pm »
Hi Antun
james
Thank you for the info James!
Cheers!
Antun
bjski
« Reply #11 on: 23 Jun 2015, 10:40 pm »
I just installed the new card. The installation takes about an hour maybe less if you done it before. My biggest problem was not having 15 torx driver. Needed to take a trip to home depot. I spent more time taking my system apart and putting it back together than installing the card.
The card from the brief listening session get it. The bass wow. I didn't think the BDP-2 could get any better but it does. The high and subtleties just jump out at you. the background is darker. A+
bjski
« Reply #12 on: 23 Jun 2015, 10:42 pm »
I have yet to listen to the BOT with the new card but I only suspect it sounds significantly better than the BDC-1.
brystoned
« Reply #13 on: 24 Jun 2015, 02:57 am »
is there a blue LED on the new audio card ?
ed
bjski
« Reply #14 on: 24 Jun 2015, 03:21 am »
No
R. Daneel
« Reply #15 on: 24 Jun 2015, 06:40 am »
James, considering that the new IAD is based on the BUC-1, would it be logical to assume that BUC-1 pffers better performance than the internal sound-card in the BDP-1/2 and that adding the BUC-1 to the BDP-1/2 would therefore improve audio quality?
Cheers!
Antun
« Reply #16 on: 24 Jun 2015, 09:36 am »
Cheers!
Antun
Its an option but integrating it directly into the BDP 2 has advantages.
james
« Reply #17 on: 24 Jun 2015, 10:16 am »
Hi biski
Yes please let me know what you think - there has always been this controversy about CD Players vs Ripped files and also in the case of the BOT-1 when you listen to a CD you are using the buffer section and electronics of the BDP-2.
james
R. Daneel
« Reply #18 on: 24 Jun 2015, 11:01 am »
james
Hi James!
I was thinking about adding BUC-1 to the BDP-1? Would this have any advantages?
I am just curious. Like I said many times, I doubt there are reasons to improve upon the performance of the BDP-1.
Cheers!
Antun
« Reply #19 on: 24 Jun 2015, 11:50 am »
Hi James!
Cheers!
Antun
Hi
I think the only reason to use the BUC 1 is if you are using a Laptop or Computer to manage and store your files.  The USB input on the BUC 1 is ASYNC so it bypasses all the computer issues with handling music files and the quality is controlled by the BUC-1 rather than the computer.  The computer just functions as your file management system. With the BDP-1 you already have a dedicated and optimized computer front end.
james
