Vision phono preamp is in the house!!!!
0 Members and 1 Guest are viewing this topic. Read 11115 times.
Wayner
« on: 5 Jun 2015, 07:37 pm »
The new Audio by Van Alstine Vision phono preamp was delivered yesterday. This preamp basically makes a SUT useless as Frank has incorporated all of the gain and loading required for virtually any MM or HOMC or low output MC cartridge available today. Several gain options are available including 40db for MM and your choice of 54, 60 or 66db of gain for MC cartridges. The cartridges can also be loaded (via internal dip switches) for 30, 47, 100, 220, 475 and 1000 ohms.
Inputs and outputs are via standard RCA, gold plated jacks. The power supply for the unit is a 16 volt, 400ma wall wart (non-switching) and uses a jack on the back of the unit for connection. The unit also comes with the standard, thumb screw ground connection point.
After zero warm-up time, I fired up Thomas Dolby's "Wireless" LP, using my plain Jane VPI HW-19jr (with the sorbothane plinth dampers), Audioquest PT-6 tonearm and one of my AT440MLa cartridges in a Lofgren B alignment.
I have heard several iterations of this preamp before, but I was certainly caught off guard with the first LP. The sonic wall now seems to have a slope to it, with the low frequencies at my feet and the reverberant sound stage much deeper and wider then heard before, ever. My newly constructed (and calibrated Vu meters confirmed uniform output between the channels) and that was evident due to the excellently centered sound stage. The second LP was from Dead Can Dance's Into The Labyrinth by Mobil Fidelity Sound Lab. One of the passages on side one (The Wind that Shakes the Barley) always sounded overloaded from Liza's powerful voice, but the new Vision walked right thru this where my other phono preamps all had produced the highly modulated parts of her vocals as an over-modulation (either from microphone or other) saturation. I thought it odd that MOFI would let this pass, but as I now realize, it was the failure of my other phono preamps.
I am also experiencing a more natural presentation of the music, and I supect its due to the fact that the RIAA EQ is more correct. The highs are not bitting, nor is the bass bloated as I have previously experienced with other pres.
It is a really nice addition to Frank's family of products.
Wayner
« Last Edit: 8 Jun 2015, 04:01 pm by Wayner »
dB Cooper
Re: Vision phono preamp is in the house!!!!
« Reply #1 on: 5 Jun 2015, 08:38 pm »
Excellent.
I know Frank has brushed this idea aside before, but that chassis size looks like it would be ideal for a headphone amplifier. He's expressed reluctance to do it because "it would cost as much as one of [his] solid-state preamps" if I remember correctly, but consider this: In today's "deep-end" audio marketplace, people are paying that much and more for headphone amplifiers. The headphone area, in fact, seems to be the one area of high quality audio that is actually experiencing solid growth. I bet an AVA headphone amp with a gain switch (to accommodate the big differences between various headphones out there) and low output impedance would sell. I hope AVA revisits the idea. They have the box pretty much ready to go.
heiba
« Reply #2 on: 6 Jun 2015, 08:22 am »
What is the recommended MM Grado cartridge load these days?  Different than in the 80's if you read the "Audio Basics" newsletter? In those days it was best to use a resistor (can't remember the value) in parallel with the standard 47 KOhm resistor.
Ola
Norway
avahifi
    • http://www.avahifi.com
« Reply #3 on: 6 Jun 2015, 11:39 am »
Grado changed the design of their cartridge coils sometime after that old recommendation for a 10K ohm load was made.
Modern high output Grado cartridges work just fine into a standard 47K ohm load.
Frank
Otis
« Reply #4 on: 6 Jun 2015, 01:57 pm »
Excellent writeup Wayner, thanks.
Otis
Wayner
« Reply #5 on: 6 Jun 2015, 02:15 pm »
I forgot to mention that all cartridge settings are done internally via dual 10 position dip switches located on the board. There are instructions for setting the switches on a label affixed to the inside of the removable cover. The switches are arranged into groups to control for either MM or MC operation, gain settings and loading. You have to remove 4 screws to remove the cover (please disconnect the power when doing so), but no need to worry about stripping out sheet metal as with all AVA products, the screws go into captive threaded inserts.
'ner
avahifi
« Reply #6 on: 6 Jun 2015, 06:12 pm »
The instruction manual/label on the inside of the cover also provides cabinet damping.  :)
Frank
Scroof Neachy
  • I like to smell stuff
« Reply #7 on: 6 Jun 2015, 06:30 pm »
It's sarcastic comments like the above that keep me from buying an AVA product.
PSB Guy
« Reply #8 on: 6 Jun 2015, 06:56 pm »
That's just silly. You don't know what you're missing.
Cornelis
Devil Doc
  • On the road to Perdition
« Reply #9 on: 6 Jun 2015, 10:22 pm »
Cornelis
It's more than just silly, but we won't go there. :lol:
Doc
Charles Calkins
« Reply #10 on: 6 Jun 2015, 10:23 pm »
  Hey Bro!!! If you buy one of Frank's excellent products and you don't like it you can send it back to him. No questions asked.
  Can't beat a deal like that. But I'm very sure if you did buy one of his products you would NEVER!!! send it back.
                                                      Cheers
                                                     Charlie
Minn Mark
« Reply #11 on: 7 Jun 2015, 01:47 pm »
Scroof might like it ( the AVA Vision phono) better if it came in a 60 lb billet aluminum case with no captive power cord....
 :duh:
minn mark
PS- I remain quite happy with my inboard MM version of the Vision phono in the AVA Insight+  pre-amp in my system.
avahifi
« Reply #12 on: 7 Jun 2015, 01:57 pm »
Hey!  The Vision phono preamp does not have a captive power cord - it plugs into the chassis.
Well - -  of course it is captive to the wall wart power transformer but I don't recall seeing many of these having IEC input and output jacks.
Frank
sfox7076
« Reply #13 on: 8 Jun 2015, 03:19 pm »
How many volts is the wall wart? Amperage?
Mary
  • AVA Associate
« Reply #14 on: 8 Jun 2015, 03:27 pm »
Here is the spec for the "wall wart"
Product Category:   Wall Mount AC Adapters
RoHS:     Details
AC Plug included/required:   Included
Region:   North America
Mounting Style:   Wall
Input Voltage Range:   120 VAC
Number of Outputs:   1 Output
Output Power Rating:   9 W
Output Voltage-Channel 1:   16 V
Output Current-Channel 1:   400 mA
Commercial/Medical:   Commercial
DC Output Connector:   2.1 mm Barrel Plug
Brand:   Triad Magnetics
DC Output Cord Length:   6 ft
Mary
avahifi
« Reply #15 on: 8 Jun 2015, 08:52 pm »
Note that the Vision phono preamp wall wart power supply is just a simple 120V AC to 16V AC step down transformer.  No internal circuits or noisy switching regulators in the wall wart.  It just moves the power transformer outside the small Vision chassis for low noise reasons.
Frank
JerryM
  • Where's The Bar?
« Reply #16 on: 9 Jun 2015, 01:17 am »
Frank
That's quite awesome, Frank.  :thumb:
Minn Mark
« Reply #17 on: 9 Jun 2015, 07:11 pm »
Wayner,
Any chance you can post pictures of the interior and the instructions?   Just curious.
Mark
Wayner
« Reply #18 on: 9 Jun 2015, 08:57 pm »
You should get the instructions from Frank in the form of a PDF. Call Frank for it.
'ner
Minn Mark
« Reply #19 on: 10 Jun 2015, 11:53 am »
Thanks Wayner.
M
