0 Members and 1 Guest are viewing this topic. Read 25612 times.
Back in the 70's particle board was prominant. Manufacturers then went to MDF because of it's superior sound quality and density. Today ply and bamboo are very popular. There is high quality MDF, ply, and bamboo, and there are top notch speakers made of all these materials, as on the contrary there is garbage MDF, ply, and bamboo. Also, any material will get damaged if you drop it on a corner, so that argument is a moot point. When properly contsructed, MDF is very stable, not to mention it's an excellent blank canvas for any type of finish, especially veneer. A good speaker designer chooses his material based on his design first, aesthetics second. Some designs are best with MDF, some ply, some bamboo. I have no problem with the Dayton cabinets in their proper context - a budget speaker or DIY project. In speakers costing from $2000 to $10,000 (like what I'm seeing at the shows) I have serious concerns. Just my 2.56 cents worth (Canadian funds)
The first time I watched air pass through MDF like it wasn't even there, when used as a wasteboard on a CNC vacuum table, I said I'd never use MDF in a cabinet again! But there are a lot more reasons not to use MDF. Honestly, the only thing MDF has going for it is cheap and easy. Cheap is the entire point of MDF, they sweep up the waste product off the floor of the mill and press it into a board. And as somebody else mentioned, MDF comes in a wide range of 'qualities'. When we do use MDF (never mount drivers to it), we use an ultra-refined product called Plum Creek that is formaldehyde free and is 100% plantation grown pine. It's much denser edge to edge, without that fuzzy velvet feel in the middle of the cross section. It's better, but still BB Ply, especially BB Ply on the end grain, is much much better. But back to the PE cabinets, my issue with them isn't so much that they're MDF, or that they're made in China, it's that the MDF they use is a very low quality. We use the cabinets in our entry level stuff, but only after extensive mods. When we're done the cabinets weigh 3x what they do to start, that's the only way I'll use them. And I NEVER use their baffles. The baffles that come with the cabinets are the cheapest MDF I've ever seen, you can literally peel layers off with your fingernails, it's like they're made of pressed toilet paper.
The cabinet affects all frequencies, not just bass. Cabinet resonances, edge diffraction, sound transmission through the walls, standing waves, internal backwave reflections, I could go on. Thinking cabinets only affect bass is fooling yourself.
***The Parts Express veneered/gloss cabinets in particular (whether or not they were available/sourced by another company prior to PE) are fantastic; they are of a level of build quality that many companies building their own cabinets in Europe/North America still do not match, despite their marketing bluster to the contrary.
It is rare for me to see a thread on a forum that just makes me angry. But now you've gone and done it.
My question is for the "no" (AVS) parties. Are your cabinets the exact same size as the PE cabinets, or do they simply resemble the same size and shape? If they are the same dimensions, why?
Hi VaporAre you kidding me right?what about filling material that dampens these thingsanyway most midrange and tweeters are back shieldedforcabinet resonance you put reinforced frames etc.I disagree with you...
You need to look at outside cabinets as well.I think you should do more research on this before commenting on vapor.
The good thing is my post is up there for people to judge,what you say to me makes no sense...
