Parts Express (Dayton Audio) cabinets used for high end speakers?
0 Members and 1 Guest are viewing this topic. Read 25890 times.
DS-21
I'm not associated with AVS, but I can think if two reasons why their dimensions might be exactly the same:
First, maybe those dimensions make very efficient use of board space and assembly jigs and workers who have it down pat.
Second, maybe the PE box was very thoughtfully designed as far as internal volume and internal dimension ratios, and/or maybe the VSA version has slightly different internal volume and internal dimensions that are ideal for their design, and it just so happened that fit like a glove in the Parts Express box's dimensions.
A third reason might be that there's no need to redesign the shipping materials.
That said, I don't buy for one second that Bertie Von's cabinets started out as different stock models than the PE cabinets, simply because of the baffle attachment and their use of the same horribly deleterious grille.
Seriously, an expensive speaker should have a less risibly-engineered grille.
Hi Vapor
Are you kidding me right?
what about filling material that dampens these things
anyway most midrange and tweeters are back shielded
for
cabinet resonance you put reinforced frames etc.
I disagree with you... :green:
There's nothing to disagree about, because it's a simple issue of "right" vs. "wrong." Here, you are the latter. Good use of damping material (which is a lot more than merely lining the walls) does help a lot with standing waves and basically kills back wall reflections, but it does nothing to address, for example, edge diffraction. Also, mere reinforcement is often not useful to deal with "cabinet resonance." Too much stiffness makes things worse, in fact. Read through the Harwood BBC papers on cabinet design. A smarter approach is the one outlined by Duke above: "strategically-placed constrained layer damping." See also the propaganda ("white papers") for the KEF LS50 or the earlier iteration of that approach, Tannoy "Differential Materials Technology."
SteveFord
Could you guys keep it civil, please?
Speaker cabinets and MDF isn't a life or death issue (unless you inhale too much).
Thank you.
leif8660
    • Von Schweikert Audio
Just out of curiosity,  besides Vapor Audio, who else here is a loudspeaker engineer that manufactures loudspeakers?
Folsom
Daedalus
Odyssey
Omega
Salk
Selah
Audio Kinesis
VSA
Vapor
Those are all of the ones with a Circle/Sub
srb
Daedalus
Odyssey
Omega
Salk
Audio Kinesis
VSA
Vapor
Not all -
Bryston
Selah Audio
Folsom
Not all -
Bryston
Selah Audio
I don't know if Bryston makes their cabinets. Forgot Selah.
leif8660
I just meant who was commenting on this thread
leif8660
Simply put...........Taterworks nailed it
Bob in St. Louis
Everybody still loves me though, right?  :thumb:
dmatt
I'm not sure.  Was your enclosure made by Parts Express?  :D
