What tubes to buy . .
0 Members and 1 Guest are viewing this topic. Read 8250 times.
jimdgoulding
« on: 7 May 2015, 05:29 pm »
to replace my 5 year old played everyday Matsushita 6922's in my Audio Research LS7 line stage?  Tell me a little bit about why you would recommend a particular tube, thanks.
Escott1377
Re: What tubes to buy . .
« Reply #1 on: 9 May 2015, 12:40 pm »
I use 6922's in my DAC and phono stage.
I like the Ediswan 6922.  To me it is very straight forward in its presentation, revealing throughout your highs, mids, and lows, and not too warm for my tastes.
I have also used Tungsgram, Tele's, Mullards, Matsushita, and Raytheon.
Raytheon would be 2nd choice, although they can be difficult to find in quad sets.  They are straight forward as well, and will last a lifetime.
Good luck -
Freo-1
« Reply #2 on: 9 May 2015, 01:42 pm »
I would check out 7DJ8's.  They are high quality, tend to be less microphonic, and are more reasonable price wise.  They are a 7 volt filament 6DJ8, and  should work in most 6922 applications.
Rocket
« Reply #3 on: 9 May 2015, 02:01 pm »
Hi Jim,
I've been reading about some very good Matsushita PCC88 tubes Upscale Audio has for sale.  They rate them very highly and sell for $30usd.
Cheers Rod
Escott1377
« Reply #4 on: 9 May 2015, 02:03 pm »
I would have suggested that as well, but not all devices can take the substitute.
I have a Cary DAC 100t and they did not recommend the sub.
But yes, they are a very good deal if the sub will work.
RPM123
« Reply #5 on: 12 May 2015, 04:04 pm »
Hi,
I have several different unused matched pair brands that may work for you. PM me if you are interested.
Glenn
Jerkan
« Reply #6 on: 21 Jun 2015, 08:14 pm »
Mullard 2493;)
Jerkan
« Reply #7 on: 21 Jun 2015, 08:16 pm »
They are a lot like the Matshushita but little more dynamic I think.
Mike Nomad
« Reply #8 on: 22 Jun 2015, 03:23 pm »
Have spent some time swapping 6922, 6N1P-EV, and 6DJ8 in a low-watt Decware.
Compared to the other two, the 6922 has an annoying loss of detail, with sloppy LF response.
The 6DJ8 has the most overall detail and tightest LF response, but, you will give up some LF presence.
The 6N1P-EV seems to be a perfect compromise. As military surplus, there are plenty available, prices are quite good, and you shouldn't have a problem finding matched sets.
JimJ
  • Ut Prosim
« Reply #9 on: 22 Jun 2015, 07:01 pm »
I loved the Amperex 6DJ8s that I had for a while with a Decware SE84CS.
I remember them being pretty pricey, though...if they weren't included with the amp when I bought it, I probably wouldn't have bought them myself.
vonnie123
« Reply #10 on: 22 Jun 2015, 11:35 pm »
This is a way to find some nice tubes for way less money.  Matsushita 7DJ8s $30.  I used them in my AH! CD player I had bought from Kevin a few years ago.
upscaleaudio.com. Kevin Deal is the owner.
sfox7076
« Reply #11 on: 23 Jun 2015, 01:52 am »
Try 6N23s with the rocket ship logo.  Almost as good as CCa tubes ten times the price.
Escott1377
« Reply #12 on: 6 Jul 2015, 12:47 pm »
I have a Manley phono stage that uses 6922 / 6DJ8 / 7DJ8.
How can I tell if the 6N1P will be a suitable sub?  The 7DJ8 is slighter hotter, which leads me to believe the Chinook would not have an issue w/ the Russian tubes.
Thanks -
sturgus
« Reply #13 on: 7 Jul 2015, 03:14 am »
Jim you should try the 7308's that Kevin Deal sells. You can get a matched pair for around $200. Well worth the price.
Sturgus
Escott1377
« Reply #14 on: 7 Jul 2015, 01:04 pm »
Sturgus
I have purchased Kevin's Ediswan 6922 x 4, his Matsushitas 7DJ8 x 4, his Telefunken 7DJ8 x 4, the Tungsgram 6922 x 4, a quad of Mullard 6922's and a quad set of Raytheon 6922 from Flea Bay.
These Russian tubes are NOS, matched Reflektors, military grade, and $18 for the quad shipped to the US.
I'm on the hunt for quality Russian substitutes since myself and a friend have had really good luck on the power tube side.
Lots of NOS Russian tubes available since someone figured out they could market their military surplus to the hi fi community.
vinylvalet
« Reply #15 on: 7 Jul 2015, 01:24 pm »
Five of the six gold grade Matsushita 7DJ8s I recently purchased from Upscale for my Herron VTSP-2A line stage were very noisy.
New production Telefunken Black Diamond E88CC/6922s from Tube Depot sound very good with almost no audible noise. They are actually JJ 6922s that have received long burn-in and tight screening. Most users report high fallout from the JJs (my experience as well). So far these "Telefunkens" are working well in my system.
Bob in St. Louis
« Reply #16 on: 7 Jul 2015, 01:35 pm »
Escott1377
« Reply #17 on: 7 Jul 2015, 02:20 pm »
I feel comfortable w/ the lot of tubes that I have for the Chinook.
I'm running tubes in my pre amp, tubes in my phono stage, tubes in my DAC, and tubes for the mono blocs feeding my tweer / mids on my speakers in a bi amp config.
Again, I'm trying to explore the world of these inexpensive Russian tubes.  Military spec means the build quality is fantastic and will meet or exceed the estimated 10k hour lifespan of a small signal tube (different vendors quote different hours so I am on the high side here).
JackD201
« Reply #18 on: 8 Jul 2015, 08:00 am »
Jim see if you can find Valvo 7308s. Do it before demand skyrockets the price. They have a touch of Mullard 2432 in the midband and a bit of Tele CCa in the bass.
Escott1377
« Reply #19 on: 8 Jul 2015, 10:45 am »
Sorry to all on this thread.  I posted another w/ a similar question and thought I was responding to my own post :)
You can see my Clemson education kicking in...
