0 Members and 1 Guest are viewing this topic. Read 18598 times.
I am not sure what there is to prove. Will your tests show some result?I am more about the music then sound quality. That said , I like good sound. For me , I plug in in my Sure846's to my iPhone 6 and I'm way happy with the sound. I sold off my speakers and bought the Andrew Jones Floor Standers with a matching subwoofer , and I am very happy with the sound for music and movies.I plug my phone right into the amp. I think it sounds very nice!!
I just spent some time further enhancing the position of my Maggies, listening to some Spotify right now as I research microphone options, and all I can say is KingDeezer needs to prepare to eat some nasty crow.If anyone has some reference tracks they'd like to request, place them here. I will also throw my Miller & Kreisels and GR Mod speakers into the mix.And The Order 1886 as well lol.Be a few more weeks though.(Oh, and SRB, great post.)
Listening to Sticky Fingers right now and am blown away by the sound quality, easily matching CD ...
Since this is the AudioCircle forum, I think this comment will generate the biggest blowback from posters. Spotify Premium maximum streaming quality is 320 kbps compressed rate vs. CD quality 1,400 kbps rate. So I think Rclark is simply stating that he cannot tell the difference between the two (wouldn't be the first to acknowledge that).Spotify is a great/ convenient resource for accessing a huge library of music. I use it all the time; but when I want to do serious listening, I listen to non-compressed .wav files or Hi-rez files.
I'm really not sure what the OP is arguing anymore to be honest.
Nevermind the notion that the OP thinks can accurately display his system's performance through a home brewed recording, and have it be a valid comparison to actually in the room listening.
"... but, better equipment sounds better (obvious). Through a 300 dollar DAC/Preamp, there likely is minimal difference between Spotify and Redbook. There might likely also be less of a difference between transports as well. Its the limitation of the equipment. A 3000 TV looks better, and is more revealing of PQ differences, than a 300 dollar TV. Same as a 3000 DAC is more revealing of SQ differences, than a 300 dollar one. Up to a certain point, more money equals better sound." I've often wondered how my own experience might differ if I had a better/excellent DAC. As it is, my DacMagic Plus allows me to hear only a small difference between my streaming 320kbps (not Spotify) music and Redbook quality. I use the streaming music for background music while I'm reading or moving about the house. I've been aware my DAC is the weak link in my system for a while now. Hmm. Time to do something about that.
You can't just say $300 DAC and dismiss it out of hand. They [Emotiva] punch well above their weight, it's why they're still in business.
No, but someone who has actually owned it and compared it to better DACs can state that in their opinion it is not an excellent DAC nor a really, really good DAC, but simply one of many decent average acceptable DACs.The Emotiva DAC in conjunction with an optical TOSLINK interface versus an S/PDIF coaxial, AES/EBU or good asynchronous USB interface might possibly explain why you're unable to discern any difference between a 320 kbps compressed stream and a 1411 kbps uncompressed CD or file when many other people can.Go ahead and make recordings of your speakers if you like, but I don't think anyone on this or any forum will be able to comprehend what in the world that endeavor could possibly prove or disprove. Steve
A useful benchmark of relative performance differences might be had if you could an get an Auralic Vega/Aries combo in your system for a couple of days. If I am not mistaken the Aries can accept a Spotify stream via the Lighting app. While it is comforting to believe that all higher priced equipment fails to deliver a level of performance that is commensurate with their cost, this is not the case. Scotty
Rclark, I just can't take you seriously. I can easily here the difference between streaming off the internet and any source I have in house. There is no way that Spotify sounds as good as a CD unless your audio gear isn't revealing enough to show it or you can't here well enough to tell the difference.Just my opinion of course.
My main issue with the thread was this statement:"a real end-game solution for music, period"Audio can be very subjective. I love the way my AVA 600r sounds. While that amp has gotten tons of praise, but there are people that don't like the sound. That's ok. It works well in my system. If you are OK with Spotify, your PS4, and a emotiva dac in your system that is great. No one can tell you that set up isn't perfect for you. The best part is, I'm sure there are plenty of other users out there that would agree that this set up works perfect for them. In fact, I'd venture to say a large portion of the population would be 100% happy with just Spotify and a PS4.On the flipside, this is a forum that is dedicated to audio with the majority of users classifying themselves as audiophiles. For better or worse, most of the people on this forum obesses over audio quality and go as far as spending hundred of dollars on audio cables, toy with towing speakers 2-3 cms in different direction to see if it affects sounds, and have invested thousands of dollars in their systems.You are not likely to find many people in that setting that will agree a PS4, an internet streaming service that tops out at 320 kbps, and a emotiva dac are the end all be all of sound. Because of this, the thread is running in circles. There is no reason to be defensive. Post your thoughts on the set up. I'm sure it will help others who are interested in doing something similar. just my thoughts.
