FS: Straley Reality speaker cables, 16 ft pair, spades, VGC ****SOLD****
0 Members and 1 Guest are viewing this topic. Read 3308 times.
sunnydaze
A very popular cable on here a few years ago.  A quick Google will get all the positive comments and reviews.
I bought this pair maybe 2 yrs ago but used it little.  Shortly after purchase my layout changed and I didn't need this long length.  Been in my closet since then.
Single wire, 16 ft long, spades all around.  It has the optional black mesh nylon sleeve.  Overall condition is excellent.  No snags, pulls, tears or rips.  Spades barely have marks on them.  Some of the ends, where the mesh sleeve meets the shrinkwrap,  are wrapped w/ electrical tape   It arrived this way from previous owner.  It's neat and tidy, and obviously has no effect on performance.  I only mention it for completeness, the condition is basically the same as I received it.
Per the website,  current retail w/ the optional mesh sleeve is $560.  I'm asking $280.  USPS Priority Mail shipping is free.  Add 3% if you don't use PayPal family / friends / gift.
Thanks for looking.
John
« Last Edit: 15 Aug 2015, 12:10 pm by sunnydaze »
sunnydaze
Re: FS: Straley Reality speaker cables, 16 ft, spades, VGC
« Reply #1 on: 1 Apr 2015, 04:50 pm »
bump
sunnydaze
« Reply #2 on: 14 Apr 2015, 12:10 am »
bump
sunnydaze
« Reply #3 on: 22 Apr 2015, 02:41 pm »
bump
sunnydaze
Re: FS: Straley Reality speaker cables, 16 ft pair, spades, VGC
« Reply #4 on: 29 Apr 2015, 04:12 pm »
You could cut these and re-terminate into two pair of more typical length.  Can reduce your cost by selling the pair not needed.
« Last Edit: 6 May 2015, 06:19 pm by sunnydaze »
sunnydaze
« Reply #5 on: 16 May 2015, 02:04 am »
bump
sunnydaze
« Reply #6 on: 27 May 2015, 11:46 pm »
Bump
sunnydaze
« Reply #7 on: 5 Jun 2015, 12:14 am »
Offers?
Darryl
« Reply #8 on: 7 Jun 2015, 05:40 pm »
Hi John,
I'm interested in your reality cables.
My problem is I would use them with vintage equipment (integrated amp, Sherwood s5000).
It's got a terminal barrier for the speaker posts, ie. posts smaller than usual.
Do u think the amp end spades would work on vintage equipment.
Darryl
sunnydaze
« Reply #9 on: 10 Jun 2015, 03:06 am »
Hi Darryl...
Just saw this now, sorry for delay in responding.
Can't say offhand if the spades will work, but I can give measurements and with them, perhaps you can determine fit.
outside width:  14mm (just a bit over 1/2 inch)
inside width is stepped:   9mm at spade tips;  6mm at spade bottom
I used calipers and measured carefully.  I also PM'd you this info, but as a member with few posts, not sure you can use this feature.
Thanks...
John
sunnydaze
« Reply #10 on: 10 Jun 2015, 03:32 am »
Here's a possible solution...
In photos I've seen these used on vintage gear:
http://www.ebay.com/itm/8-Banana-Spade-Fork-Plug-Fisher-80-202-Eico-Dynaco-/330504308886?pt=LH_DefaultDomain_0&hash=item4cf3978896#ht_2981wt_1165&afsrc=1&rmvSB=true
If you look at my pics showing the Reality spade, there are two solid feeling wires going into each one.  I'm guessing it's real easy to just cut them off, strip back the insulation, and insert the bare wire ends into these adapters.  Of course, I have no idea if the wires are too thick.
I believe these old barrier strips were made to screw down on very thin bare wire.  Many modern cables, even with bare ends,  would be too thick.  Hence, these fork plug adapters.
sunnydaze
« Reply #11 on: 19 Jun 2015, 06:53 pm »
bump
sunnydaze
« Reply #12 on: 7 Jul 2015, 04:29 pm »
bump
sunnydaze
« Reply #13 on: 29 Jul 2015, 03:42 pm »
Quality cable for a long run application.
Make offer.
sunnydaze
« Reply #14 on: 7 Aug 2015, 12:38 pm »
bump
sunnydaze
