0 Members and 1 Guest are viewing this topic. Read 11022 times.
Looking forward to your comments on how they compare. It would also be helpful if you can share what electronics you are driving them with. TIA!
Feel like stripping the socks off?The best guess is that they added damping material to the midrange section while the crossover remains as before.
Thanks for the review.Were you able to peer through the socks to see what's up?
Does this imply that Mye stands for the 3.7 won't fit the new i's? Or just fit differently?If the latter, are you keeping the Mye stands? How would you compare the sound improvement from the stands compared to the i?
What is this bigger hardware?
