IEC Inlets for Ncore
0 Members and 1 Guest are viewing this topic. Read 4449 times.
zenpmd
« on: 8 Mar 2015, 06:08 pm »
Any recommendations? I am thinking of using a filtered version like this
http://schaffner.com/en/products/emcemi/category/iec-inlet-filters.html
jtwrace
    • TIPP YouTube Channel
Re: IEC Inlets for Ncore
« Reply #1 on: 8 Mar 2015, 06:09 pm »
Bruno doesn't recommend that type of IEC.
http://www.audiocircle.com/index.php?topic=106336.0
zenpmd
« Reply #2 on: 8 Mar 2015, 06:13 pm »
For what reason? I want a super vanilla IEC in that case - no switch (as I am making one on the front)
zenpmd
« Reply #3 on: 8 Mar 2015, 06:14 pm »
Also - your recommended IEC inlet wont fit on the silicon ray hole?
Thanks for this by the way (sorry didnt want to sound negative above!) :)
jtwrace
« Reply #4 on: 8 Mar 2015, 06:34 pm »
I can't remember what his reason was.  Sorry.
Really?  Strange since I used the one with the switch in the Silicon Ray cases when I did the tour builds.  It's been a while though and there are plenty of IEC connectors that do fit. Heck, I think SR ships the cases with an IEC that fits.   ;)
jtwrace
« Reply #5 on: 8 Mar 2015, 06:35 pm »
satfrat - I hope you're well!   :thumb:
zenpmd
« Reply #6 on: 8 Mar 2015, 06:38 pm »
I just hate my siliconray, my fault for buying the montrosity. I wanna build something out of wood. Perhaps a wooden box to surround the silicon case would make sense. I assume that wouldnt cause any issues (though Im still trying to work out how to vent mine better, I basically just want a big mesh on top)
jtwrace
« Reply #7 on: 8 Mar 2015, 06:42 pm »
I thought you built some already.  Guess not.
zenpmd
« Reply #8 on: 8 Mar 2015, 06:44 pm »
One, badly, I am still rebuilding it!!! Listening to headphones for months. I am so bloomin busy!!! (bad excuse I know!)
DaveC113
  • ZenWaveAudio.com
« Reply #9 on: 8 Mar 2015, 06:49 pm »
I prefer the Furutech IECs with rhodium plating, they have two... the pricey one (FI-33 I think) uses wire clamps like their receptacles, the other much less expensive one has tabs you can solder to or use push connectors.
zenpmd
« Reply #10 on: 8 Mar 2015, 06:51 pm »
I actually have two Oyaide ones, since I couldn't find anything else that fit at the time!! Platinum and Palladium or something stupid. I am annoyed at this since i want to use the same metal as on my iec cables...
santacore
« Reply #11 on: 8 Mar 2015, 06:53 pm »
I too used the Furutechs with the screw clamps. Reasonably priced and worked with my Silicon Ray case (although I might have had to a bit of filing to make them fit).
xsb7244
« Reply #12 on: 8 Mar 2015, 08:56 pm »
If you can afford it the Furutech Fl-33 R.  Sonic Craft has a sale for the month of March
zenpmd
« Reply #13 on: 12 Mar 2015, 12:30 pm »
Can anyone tell me what I need to look for in terms of spec for cables?
I dont subscribe to power cables making a difference, but its having enough amps etc I need to think about. I want a locking device, like the below. Would they work? Thanks!
http://uk.farnell.com/schurter/6051-2008/lead-v-lock-uk-plug-c13-2m-blk/dp/2064393
occamsrazor
« Reply #14 on: 12 Mar 2015, 01:52 pm »
Not tried them myself, but if you are looking for those IEC-lock connectors Canford also have a range:
http://www.canford.co.uk/AC-MAINS-POWER-LEADS-IEC-LOCK
http://www.canford.co.uk/AC-MAINS-POWER-LEADS-IEC-LOCK+
...only thing is they use 1.0mm2 wire, not sure whether you might want something beefier or not.
Julf
  • Grumpy second cousin of Mark V Shaney
« Reply #15 on: 20 Mar 2015, 09:41 am »
The typical T or pi filter actually connect the mains and the supposedly totally isolated earth/ground (through a capacitor).
zenpmd
« Reply #16 on: 20 Mar 2015, 10:03 am »
In the mean time my Shurters have arrived and look great
