phono preamp upgrade!
0 Members and 1 Guest are viewing this topic. Read 5227 times.
sleepkyng
« on: 23 Sep 2004, 03:45 am »
i've got somewhere's round 200 bucks
and i want to upgrade my phono preamp
i was thinking graham slee? where can i get one in the US?
any other reccomendations?
cheers!
dogberry
« Reply #1 on: 23 Sep 2004, 12:40 pm »
What's your setup now?
Why not add your system to the database?
sleepkyng
« Reply #2 on: 23 Sep 2004, 04:55 pm »
Brad
« Reply #3 on: 23 Sep 2004, 07:04 pm »
Everybody I found selling the Gram Slee wanted list price for it.
Still, supposed to be an excellent phono stage.
Jay at Audio Revelations (find on Audiogon) carries them.
dogberry
« Reply #4 on: 23 Sep 2004, 08:47 pm »
For your system I'd recommend the NAD PP-2.  You can get it for under $150 on the web.
My friend just got this for his low bedget analog system and it's pretty nice for the price!
sleepkyng
« Reply #5 on: 23 Sep 2004, 10:02 pm »
i was thinking about also the parasound zphono as it has gotten really great reviews and is only 120 new!
Tonto Yoder
« Reply #6 on: 23 Sep 2004, 10:34 pm »
Michael Fremer reviews BOTH the NAD and Parasound in the latest Stereophile--no clear winner, but seemed the Parasound was the better with MM, NAD with MC. His comments were surprisingly good given their low price. BTW, he gives the Parasound price as $150.
duff138
« Reply #7 on: 24 Sep 2004, 12:12 am »
http://www.hagtech.com/index.html
Bugle assembled is $175
find a case for $25
=$200
heard it's a great phono amp.  worth checking out
sleepkyng
« Reply #8 on: 24 Sep 2004, 01:23 am »
is my setup mc or mm? <-- dumb question but important
Tonto Yoder
« Reply #9 on: 24 Sep 2004, 09:44 am »
Quote from: sleepkyng
Audio Technica mostly makes MM carts, the OC-9 being the only exception I know of (but there may be older models).
https://system.netsuite.com/core/media/media.nl?id=2738&c=ACCT106601&h=b49f502b7a85fb443eec&_xt=.pdf
Generally, cheap phono stages would only permit use of MM carts (which also tend to be cheaper/ less expensive): that's why inclusion of MC capabilities in the Parasound & NAD PP-2 are surprising at the price. The NAD PP-1, for instance, didn't have MC compatibility.
doug s.
  • makin' music
« Reply #10 on: 24 Sep 2004, 01:36 pm »
i'd recommend the acurus p10 fono stage.
http://www.klipsch.com/product/product.aspx?cid=307
http://www.klipsch.com/media/Products/P%2010%20phono%20pre%20om.pdf
while i never heard it, several folks said it was a lot nicer than the usual suspects like the phonomena, black cube, etc., a while back when i was in the market.  i ended up w/a much pricier unit, which i really like  - the pentagon ps-3.
doug s.
viggen
« Reply #11 on: 24 Sep 2004, 11:54 pm »
I was at Audio Revelations last weekend, and I wasn't aware that he carried GS.  GS is only MM though.  Less flexibility.
I did try out four of his phono pres, some Thor, two Trichords and a Dynavector plus this built in phono in a Rowland unit which is on a different system with a different table.
To my ears, the cheap Trichord, the Dino, sounded the best.  Compared to the Delphino, it's slightly smaller sounding but felt its more precise especially with brass.  My friend liked the Delphino better.
Both were better than the Dynavector and Thor.  Jay thought there might have been a bad tube somewhere with the Thor.  The Dynavector wasn't bad either.
This was in a complete Thor system with Kharma speakers and Origin Live top of the line table.
BTW, Jay is excellent and highly recommend doing business with him.
lcrim
« Reply #12 on: 27 Sep 2004, 04:57 pm »
The Trichord Dino lists for $470 w/ standard power supply.  I agree that Jay is a nice guy but I doubt that he will discount that down to the $200 range.  @ $150  plus shipping the Hagermann Bugle, suggested earlier,
would also be my choice.  Since your cartridge has a listed output of 5.6mV, I would think that choosing a gain of 40dB on the Bugle would be about right.
The Bugle can be ordered as a kit but also can be bought prebuilt,  battery powered.   A separate AC power supply can only be found as a kit.
I think it was mentioned that there is a forum right on this board.
doug s.
  • makin' music
« Reply #13 on: 29 Sep 2004, 06:37 pm »
ABEX
« Reply #14 on: 30 Sep 2004, 05:32 am »
Checkout Gram Phono Amps which are small and lightweight which I like. Best of all they are inexpensive!
Good luck!
