Looking for a small speaker project (0.25 cu/ft)
0 Members and 1 Guest are viewing this topic. Read 2294 times.
sts9fan
« on: 18 Feb 2015, 05:27 pm »
I have a 0.25 cu/ft parts express cabs that I want to build a project in.  I have a sub so sealed is fine/good.
Right now I have only found the Zaph one at Madisound.  https://www.madisoundspeakerstore.com/2-way-speaker-kits/zaph|audio-za5.2-tm-2-way-pair/
Anyone got others?
srb
Re: Looking for a small speaker project (0.25 cu/ft)
« Reply #1 on: 18 Feb 2015, 05:40 pm »
The link doesn't work, though with no fault of your own (other than not testing it).  The pipe symbol (|) used in the name "Zaph|Audio" doesn't work with the forum's hyperlink code, and I suspect it would have problems with some other forum software too.
The closest you can get is with a search link Here's a link generated using the site's search:
https://www.madisoundspeakerstore.com/index.php?p=catalog&mode=search&search_in=all&search_str=za5.2
Edit: I didn't think of using Ruben's solution in the following post to use the %7 character code for the pipe symbol - although this is the first time I recall running into it in a link.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
GT Audio Works
« Reply #3 on: 18 Feb 2015, 06:14 pm »
Is the front baffle already cut out or yet to be routed ?
sts9fan
« Reply #4 on: 18 Feb 2015, 06:52 pm »
I have two uncut baffles
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #5 on: 18 Feb 2015, 07:29 pm »
0.25 ft^3 = 7 litres.
Quite a number of 4ish inch full-ranges that work in 7 litres. They may need to be vented to reach down to where sub(s) can be XOed.
dave
sts9fan
« Reply #6 on: 18 Feb 2015, 07:48 pm »
Definitely not looking for full rangers.  I had some Alpair 7.3s in there till one failed.  I will vent.
srb
« Reply #7 on: 18 Feb 2015, 08:11 pm »
Here's a sealed 2-way designed for the Parts Express .25 cu. ft. cabinets
Swope TM from Meniscus Audio
  - 5.25" Hi-Vi midwoofer
  - 20mm Dayton Audio soft dome
S Clark
« Reply #8 on: 18 Feb 2015, 09:20 pm »
This uses a nicer tweeter.  I've built a pair that I keep in the kitchen.  It's for a slightly smaller box, but could be made to work.
http://www.rjbaudio.com/Microbe%20SE/microbe%20SE.html
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #9 on: 19 Feb 2015, 01:51 am »
Silver Flute W14 works in that volume. You are on your own for tweeter & XO.
dave
