New X-LS encores!
0 Members and 1 Guest are viewing this topic. Read 5126 times.
greenklein
New X-LS encores!
« on: 4 Feb 2015, 02:00 am »
Well I really enjoyed building my A/V-3's and A/V3s last year, but I've always wanted to build the X-LS Encores, so I finally pulled the trigger on them.  I just finished them a few days ago.  I hooked them up, turned on the stereo and smiled.  I'm not even sure what I'm going to do with them.  They match the A/V's so they would be nice as the surrounds, but I'm thinking they're too nice for that.  Oh well, I'll figure it out.  Present to the Parents?  Well, here are a few pics.  No upgrades on these besides the No-rez.  I had some extra from the A/V build.  Ok, I've spent enough time trying to rotate the images...They look right in the gallery...Sorry.
White Oak Veneer and rattle can gloss black.  White oak finished with stain sealer and 7 or 8? coats of wipe on poly.  I don't believe the imperfections will show up on the pics!  I hope...
Just testing them out next to the A/V-3's!
The A/V-3s was feeling left out...  The A/V-3's were painted with a semi-gloss enamel using my airless sprayer.  I was originally going to do that with the encores, but it was too much of a hassle to run paint through the airless and clean it out for the size of these, so rattle can it was.
Thanks everyone for posting pics/builds etc.  It is very helpful...There is some incredible work done by people on this site.
What's next?  I kinda want to build a new sub box for the existing sub, but have no idea how to go about that.  I would like to build one of Danny's subs, but that is not going to be in the budget.
Thanks Danny for the cool projects!
Todd
mresseguie
Re: New X-LS encores!
« Reply #1 on: 4 Feb 2015, 02:27 am »
Very nice looking!
 :thumb:
 :cry: (Crying over my poor carpentry skills and lack of tools)
Michael
mlundy57
« Reply #2 on: 4 Feb 2015, 03:07 am »
Very nice. How did you get the painted baffle with the veneer?
Mike
cody69
« Reply #3 on: 4 Feb 2015, 03:20 am »
Nicely done -- look great! The black baffle and veneer look great.
No doubt you'll enjoy these.
Guy 13
« Reply #4 on: 4 Feb 2015, 03:34 am »
Really nice work greenklein.
Guy 13
« Reply #5 on: 4 Feb 2015, 05:51 am »
nicely done  :thumb:
Pretty impressive little speakers  huh ?
-jay
Rocket
« Reply #6 on: 4 Feb 2015, 10:41 am »
Hi,
Very nice looking speakers.
Thanks for the photos.
Cheers Rod
jeffh
« Reply #7 on: 4 Feb 2015, 04:02 pm »
greenklein,
Your speakers look very nice.  I really like your finish on the veneer  :thumb: :thumb: :thumb: :thumb: :thumb:
Danny Richie
« Reply #8 on: 4 Feb 2015, 05:31 pm »
Looks great! Nice job.  :thumb:
devinkato
« Reply #9 on: 4 Feb 2015, 08:04 pm »
Looks great - best value in DIY!
greenklein
« Reply #10 on: 5 Feb 2015, 02:05 am »
Thanks everyone, I really appreciate it.
Mike
Mike,  I glued the baffle on after I did the veneering and finishing.  I used some blue tape on the seams to keep the glue off too.  I'm not sure I needed to since with the finish it would have been easy to use a wet rag and clean the glue off.  After using the flush bit and round-over I masked up the rest of the speaker using "frog" tape on the baffle edges (it makes a very clean line), prepped and painted away.  I did 4 coats of primer and 4 coats of paint.  I let the finish dry for a couple of days before I removed the taped edges.  It came off very cleanly.  I thought I would have to use a knife, but nope!
Todd
« Last Edit: 5 Feb 2015, 05:00 am by greenklein »
mlundy57
« Reply #11 on: 5 Feb 2015, 03:09 am »
Todd,
Do I understand correctly, you ran a flush trim bit around the baffle after you finished the veneer? If so, didn't that mar the finish?
Mike
greenklein
« Reply #12 on: 5 Feb 2015, 05:07 am »
Mike,
I put some blue tape on the finished veneer right up to the baffle.  The bearing of the trim bit didn't seem to bother it at all.  I don't believe I finished the A/V's before I put the baffle on.  Finishing the encores first was a good step I think.  Tape went on nice and came off nice and it made glue clean up easier too.  After I clamped the baffle on, and the glue spilled out, I pulled the tape and then ran a wet cloth around all of the clamps (kind of a pain) but the glue came right off.  I'm sure there is a better way to do this, but it seemed to work just fine.  The lines on the Encores are cleaner than the A/V's although you really have to look.
Todd
ps.  I've enjoyed looking through your build threads the past year and a half.  Thanks for posting.
mlundy57
« Reply #13 on: 5 Feb 2015, 06:08 am »
Todd,
Thanks and you're welcome. Having all these folks to ask questions and bounce ideas off of is a real blessing.
Mike
Ron
« Reply #14 on: 5 Feb 2015, 11:29 am »
Nice work Todd. Your speakers look great ! Do they have the performance upgrade mods ( Sonicaps, Mills, No- Res ) too ?
rockdrummer
« Reply #15 on: 5 Feb 2015, 01:19 pm »
Todd, I have always leaned towards black for the entire speaker, regardless of size, but I really like that front baffle look.  I am going to look into learning about veneers next.
I built a pair of those for my brother and I'm going to get a pair of them for my daughters' dance studio.  Great sounding speakers.  I used to work at Audio King back in the day.  I don't remember any small monitor speakers ever sounding as good as those encores or AV 1's my parents have.
How do you like those white lightning speaker cables?  I read about that and wanted to try it.
Anyway, great looking work.
Ben
HAL
« Reply #16 on: 5 Feb 2015, 01:36 pm »
People should think of the X-LS series as the Dynaco A-25 of the 21st century.  One of the best sounding mini-monitors I ever heard.
Still have two pair of them in piano gloss rosewood.  They sound and look great.
I took one pair of X-LS Classics that I had upgraded the crossovers parts into a gathering one time with a pair of X-LS Encores as a comparison.  The crossover upgrade made the Classics sound great.
Still have to build a pair of X-LS Encores at some point.  Ruben is doing flat packs soon.
greenklein
« Reply #17 on: 6 Feb 2015, 05:04 am »
Ron, I did not do any of the upgrades.  I had some no-res from my A/V build last year that I used (a full sheet and a few small pieces - perfect!).  I opted to save a little $$.  Tempting to build another pair w/ the upgrades to compare, but since I don't even know for sure what I'm going to do with these...haha.  I think they sound great as is.  I am very happy with them.
Thanks Ben.  I've found veneering to be fairly easy.  I used paper-backed veneer with the iron-on method and Titebond.  Using raw veneer appears to be a little tougher, but I would like to try that sometime with some more unique veneer than good ol white oak.  I was nervous the first time I veneered (the A/V's in the pics above), but after a trial piece I was ready to go.  Thank goodness for the internet and youtube and the various builds on this site.  I did take some pics if you're interested and I can detail the process a little more if anyone would like.
As for the White Lightnings...I did that because I thought they looked better than the traditional speaker wire.  I'm pretty sure that I couldn't tell any difference sound wise.  I personally like the looks though and even though no one can see them, I know they're cool looking!   :lol:  This time around I need some new cable so I just ordered 14 gauge monoprice in-wall cable and did basically the same thing with that.  I also bought some flex-tech from parts express for $6 just to see how it would look.  Looks kind of cool!  To me anyway.  I would not be able to offer any opinion on the quality of either and whether it makes any audible difference.
« Last Edit: 6 Feb 2015, 02:44 pm by greenklein »
