B135 amp. (or part of..) does not sound so good
0 Members and 1 Guest are viewing this topic. Read 2094 times.
JensUlrik
« on: 3 Feb 2015, 11:58 am »
Hello from Denmark !
I received a B135 a month ago but have had various problems - maybe some of
you have had the same problems:
1) Used as an Integrated amp the sound is rather harsh/agressive
Used as an power amp only the sound is very good. Can this be
due to 'breaking in' ? I have not used the amp for more than 50 hours i think.
2) There is a very distinct and somewhat loud  'hum' when listening to headphones.
I have tried disconnecting everything from the amp and the hum is still there.
3) Sometimes when turning on the amp there is a very loud 'pop' from the headphones
 - not from the speakers  .
4) When using an empty line-in and turning the volume all the way up, there
is a very nasty noise from the loudspeakers. This is not the case when using
a 'live' line-in (different noise then :-)   )  .
5) The frontplate gets 'very' hot after 6 hours or so - is this due to some
special design of the B135 ?
Thats it  - im am certainly not giving up on the amp but are looking forward to do some 'work' on the amp and hope
that this forum can help me on the way
NB: My speakers are B&W 683s2 and I use a 'non oversampling' tube fitted DAC as source.
Jens Rasmussen
William D. Lester
Re: B135 amp. (or part of..) does not sound so good
« Reply #1 on: 7 Feb 2015, 03:37 pm »
I've had the same amp for about 2 months now. I can't speak to most of your concerns but mine also seems to get quite warm / hot ? towards the ends of the front panel. I just assumed that this was normal. Mine did blow the internal fuse once when powering on. The reason for that isn't quite clear and it only happened once.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 7 Feb 2015, 04:15 pm »
Hi Folks,
It will run warm as we use the front panel as well as the side heat-sinks to dissipate heat.
james
JensUlrik
« Reply #3 on: 7 Feb 2015, 08:19 pm »
About the fuses : I had to use  'slow burn' fuses instead of the 'fast burn' which came with the amp.
Jens u.
William D. Lester
« Reply #4 on: 7 Feb 2015, 08:34 pm »
I have done that as well after checking with the service people at Bryston.
William D. Lester
« Reply #5 on: 7 Feb 2015, 11:45 pm »
I should have also added that I am very pleased with the B135. Sounds great to me. And I'm also very pleased with my Bryston speaker cables.
