0 Members and 1 Guest are viewing this topic. Read 10518 times.
I'm planning on building it as soon as the boards become available at the DIYAUDIOstore.Best,Anand.
I don't know if this is any help, I have Threshold in a second system and using Pass X250, I've never used the First Watt gear, however, if the higher power amps are any indication the First Watt is really good.If you have already heard First Watt and wanting something on that model specifically, my apologies.
If you have efficient speakers, the First Watt is better than the Pass. If you have low efficiency speakers that are difficult loads, then the Pass will be a better match.DIY Audio Store - has all the boards, pre-drilled chassis, and connectors you'll need to build most of the First Watt amps - http://www.diyaudio.com/store/
