0 Members and 1 Guest are viewing this topic. Read 9852 times.
Hi guys, I have a small 2 channel system and run the Dayton DTA-120 and mainly plug my iPhone into it. I want to step up my audio quality and I am looking for a dac $150 or less to plug my iPhone into and then route into the dayton. I am looking at the Schiit Modi with Uber and the XiangSheng unit. Anyone advice or other options to fit the bill would help with my decision. Thanks.
What makes you think that merely adding a new box will "step up [your] audio quality"? Is there a measurable deficiency in the iPhone's analog output when driving a line-level load that you can point to?Feel free to buy whatever, but realistically it won't actually do anything to the sound.
My question is about the meaning of your post. Are you saying the output from the iPhone is so poor that nothing could improve it, or that all DACs sound the same and none are any better than an iPhone?
I have an old Gen 3 iTouch that I use for a portable system outside in the summer. I have used LOD cables out of the same iTouch in the past, to a good headphone amp and thought it was good. I found that the headphone output was not as good as the LOD cable, but it could just be me.
If you are fond of the sound of the DAC in the iPone, why not use a breakout cable from the headphone out to the amp you recommend?
I recall that there are a number of iPhone specific DAC's and lots of happy users.
