What DAC to Pair with Dayton DTA-120?
0 Members and 1 Guest are viewing this topic. Read 9850 times.
I.Greyhound Fan
Re: What DAC to Pair with Dayton DTA-120?
« Reply #20 on: 31 Dec 2014, 05:09 am »
I would rather have the Maverick D-1 classic  over the HiFi Me and up grade the op amps for $10.  I think you can buy it for $129.  I bought a HiFiMe DAC for my daughter to use with her Nexus 7 and it does not work.
http://www.mav-audio.com/store/index.php/dac/tube-magic-dac-d1-2.html?SID=jjv8v4eqvk1gqmlihji8ikcpb2
It's a great except if you want to use it for usb.  The newer D1 Plus or D-2 would be the way to go for the improved USB section.
If you just need a DAC for USB, get a Dragon Fly.  I bought Version 1 for my son and it sounds great.  Here is one on sale-
http://www.amazon.com/dp/B00882U782/ref=dra_a_rv_lb_hn_it_P1400_1000?tag=dradisplay-20&ascsubtag=4a251a2ef9bbf4ccc35f97aba2c9cbda
DS-21
« Reply #21 on: 31 Dec 2014, 02:53 pm »
[The Dayton DTA-120] performs well for what it is.***
I disagree with that assertion. It is simply not a high-fidelity amplifier, unless you're driving speakers that are resistive loads, because its frequency response will track the impedance curve of the driven loudspeaker. A high-fidelity amplifier will have flat frequency response regardless of the driven load.
I.Greyhound Fan
« Reply #22 on: 31 Dec 2014, 06:40 pm »
That may be so, but the little DTA still sounds good for its price and what it was intended for.  I have the 100a and it has tight powerful bass and airy sound with a wide sound stage.  I paid $59 on sale and it was the best $59 I have spent.  Connected to a good source and a pair of Monitor Audi S1's it sounds pretty good.  Certainly not hifi but definitely mid fi.
Can it hold a candle next to my Pass amp, BAT preamp and Magnepan speakers, no! But it is certainly enjoyable to listen too and that's what it is all about.
srb
« Reply #23 on: 31 Dec 2014, 07:46 pm »
Apparently if it doesn't measure well on paper, there's no way it might be enjoyable to listen to.  You just think it is.   ;)
BTW, I have a Scythe Kama Bay Kro SDA-1100 amp (Yamaha YDA-138 Class D chipset) that within the scope of its 10W/ch output I also find enjoyable to listen to and well worth the $40 cost.  I admit I never looked at any frequency response graphs.
DS-21
« Reply #24 on: 1 Jan 2015, 11:50 pm »
Please read better. There is no way a competent English speaker could have extracted that from my posts.
charmerci
« Reply #25 on: 2 Jan 2015, 09:27 am »
You can also look into the ODAC ($100/150). I've been using one for years and it's really nice.
