0 Members and 1 Guest are viewing this topic. Read 16589 times.
If you want to try putting a panel behind the VR33's woofer, I'd suggest a pair of large, heavy butcher block cutting boards instead of plywood, MDF, etc. That stuff will resonate where the cutting boards will be inert. You can always pick up a pair of them and return them if they don't work out.
My VR33's are on an outside wall. I bought these speakers ONLY because they were advertised that they were made to go close to the wall in a typical living room. I have a typical living room that 2 lesser pairs of speakers (Vandersteen 2ci and Odyssey Kismet Reference floorstanding speakers) sounded much better in the bass department with exactly all the same equipment. If you look at the picture on the left side you will see the Kismet speakers and where they were placed and the size in relation to the VSA speaker. On the right is the VR33 in place on it's spikes. You can clearly see the Odyssey speaker blocking part of the TV which was what I was trying to alleviate with the VSA. The bass from the Odyssey speaker was and is spectacular and goes as deep and is much more full and defined compared to the VSA speaker.I'm out of ideas.
