Tyler Decade D2 Crossover Build
0 Members and 1 Guest are viewing this topic. Read 2282 times.
rjryan
« on: 30 Nov 2014, 06:32 pm »
I've had my Tyler D2's now for about two years and have been extremely happy with them. After I purchased them slightly used directly from Ty, I contacted Danny through AC to see if I could get the frequency response specs. I had read that he designed the drivers and x-overs, so I figured he'd know. He promptly obliged, and he mentioned some upgrades that were available that he said would improve the sound noticeably. Long story short...he was right!!! I finally got around to ordering the parts a few weeks back, and just finished the build.
The upgrades consist of: Sonicaps, Erse XQ coils and Pulse X polycaps, Mills resistors, new internal solid copper wire, No-Rez, and Electra Tube Connectors.
The imaging is much better, they are more spacious, and there is no "smear" in the sound at all. They quite simply play "bigger" than they did.
I actually did one at a time so I could critically listen to the stock and the upgrade side by side, and there was a marked difference in the way they sounded. Much tighter low end with more accurate midrange, and smoother highs. I could not be happier!
To be clear there is NO offence to Ty meant here!! He's a true gentleman and builds one hell of a good speaker, IMO. He actually mentioned that a lot of mastering studio guys were upgrading the crossover and such, but I opted to stick with the stock configuration at the time, rather than have him install the parts.
Here are some pics of my install and system. Thanks for the advice and your prompt shipment of the parts, Danny!!!!
Crossover build:
Wired up and ready to install
No-Rez
Installed and ready to re-stuff with batting and replace drivers
Kicking back and enjoying some music...
The business end (equipment listed below) I have small children, so I keep it behind closed doors 8) I did the install and custom shelves myself
Associated gear:
Marantz AV 7005
Project Xtension 10
Musical Surroundings Phonomena II
Cambridge Audio Azur BD751
Mac Mini
Schitt Bifrost
Belles 150 A Hot Rod 3 channel
Niles 245
Niles 275
Tyler Acoustics Decade D2
Tyler Acoustics Decade Center
REL S5 subs
Cambridge Audio Aero 3 surrounds
« Last Edit: 10 Jan 2015, 04:48 am by rjryan »
rjryan
Re: Tyler Decade D2 Crossover Build
« Reply #1 on: 6 Dec 2014, 09:03 pm »
I just thought I'd give a little update after around 100 hrs of break in:
Wow. Just wow.  If you own a pair of these and haven't done the upgrade, run, don't walk!
Thanks for the great advice, Danny!
AKLegal
« Reply #2 on: 7 Dec 2014, 01:16 am »
I have to concur with what you are hearing.  The D2s ultimately proved to be too much speaker for my room but Danny's x-over upgrade along with lining the cabinet with no res worked wonders.  If I had a large room I doubt I would have sold them.
rjryan
« Reply #3 on: 7 Dec 2014, 01:45 am »
I've actually been in touch with him already to upgrade my center channel, too. My Decade Center sounds like it has a bit of a cold compared to the D2's now :lol:
rjryan
« Reply #4 on: 13 Dec 2014, 08:12 pm »
...and the center channel is completed! Same crossover as a Decade D3 or D3M. The same stunning difference applies  :D
Here are pics of the old crossovers, and the new ones I assembled from Danny.
