0 Members and 1 Guest are viewing this topic. Read 9360 times.
Good description JLM. I would mention Alnico and Full Range drivers without a xover as most free fatigue to my ears.
Didn't want to toot my own horn (speaking figuratively ), but that's exactly what I have (Fostex F200A extended range drivers with F3 = 30 Hz and AlNiCo magnets in Bob Brines transmission line cabinets).
So far, in my limited experience, it does seem that fast transient speed & high resolution come from speakers that may be termed more 'analytical' and less 'warm' or 'organic'.
Questions: 1. Is it a necessary correlation that fast transients & high resolution result in an analytical sound?2. And that a fast transient & high resolution often result in fatigue if listened long term ?3. OR are there speakers out there that have very high transient/resolution but is acknowledged by most as warm, easy to listen to, non-fatiguing? I've not encountered such speakers in the lower $ range under $2-3K but then I've probably only sampled 1/10th of 1% of all the speakers in this range - if not less. Thanks in advance for any insight. UL
UltraLight,I think it is easy for an audiophile to get hung up on speakers. It's a learning curve for the new guy, and it's a problem that some of us never outgrow. We focus all of our attention and budget on the speakers, taking for granted the source component and the amplification.It took me a long time to accept the idea that it should be the other way around. The speakers are at the end of the chain and there is really only so much that they are responible for. If the source and amplification are average or mediocre, the sound will be mediocre no matter what kind of speakers you have. On the other hand, put a decent 700 dollar pair of bookshelf speakers on a 20,000+ dollar front end and you will shake your head in disbelief. "I had no idea those speakers could sound so good. Play it again...." I have tried this crazy experiment once at a high-end shop, and a couple of times at home. High quality, top notch source components and amplification retain most of their stellar sound on inexpensive speakers. Of course a better pair of speakers will make them sound even better, but that is not the point.Now hook up a value-oriented front end and amplification to a 20,000 dollar pair of speakers and see how quickly you loose interest in listening to music. Sound familiar? Notice anyone (everyone?) approaching it this way and still looking for better sound? I think everything that comes before the speaker is more important than the speaker itself. The source component, the preamplifier and amplification are where you should be focussing these questions. They are excellent questions, but they need to be aimed at the entire system, not just the speakers.
Not with planars. Directional speakers will do small soundstage.On this road an anechoic chamber is a ideal room.
I find that wide dispersion speakers generate more realistic results than directional systems. I have a pretty live room, but use a dozen GIK dispersion units, three stacked sets per side at the speakers' first reflection points. I use a pair of subwoofers at the back of the room, about 48 feet from the fronts of the speakers with a 150 degree phase offset dialed in for the front/rear woofer overlap frequency. The system has a wide horizontao range of very good listening positions and much reduced bass room nodes.
