0 Members and 1 Guest are viewing this topic. Read 9414 times.
Thank you EVERYONE for responding.I am trying to ask question systematically, step by step which is why I asked about speakers first - but certainly appreciate the answers responding to the spirit of my question - which is how to avoid listening fatigue while retaing very accurate timbre which I think requires, among other things, fast transients and high resolution. Good responses all, and quite helpful.Off the top of my head in responding to some posts: I distinguish between dynamics and fast transients. Dynamics is the difference in amplitude or volume of the sound. Transient is how fast the sound is generated and ended when the signal ends. Am I off? Also, I agree that there needs to be synergy so I do not think that I am prioritizing speaker over or below the entire signal chain. I can't think of one thing that I would like to compromise. As to uber $ speakers being able to reproduce very accurate timbre and yet without fatigue, I'm not surprised. (Tidal Piano looks fabulous .) The trick is to find it on a budget.... Your comments are all helpful and appreciated. UL
What about reflections causing listener fatigue? Everyone is focusing on the voicing of a speaker, which, you can't even accurately hear in an untreated room. This has been my experience. If you play a speaker with a healthy amount of volume, in an untreated room, you are going to risk listener fatigue. Doesn't matter if you have 2K or 20K speakers.
Tyson I have a possible cure for your 16/44 problem. Borrow a Auralic Vega and try it out with your problematic 16/44 recordings. I had one in the house for an over-nighter and it did things with 16/44 recordings that I just could not believe. Never mind what it did with Hi-Rez recordings. You never know it might work for you.Scotty
Hypothetically speaking, it would be all to easy to assemble a system full of components with a host of non-linear errors and blame the messenger in the form of the loudspeakers for telling the truth about what is happening to the signal upstream from them. This would set one up to make a buying decision that trys to cover up the damage done to the signal upstream from them. This is roughly analogous to putting a bandaid on a death wound. I think a closer approach to High Fidelity reproduction might result from the purchase of a more truthful or accurate to the source pair of loudspeakers and then attacking the problems that exist in the rest of the components in the system.Scotty
The second biggest contributor to fatigue that's not power per say, is electrical resonances/ringing.
