0 Members and 1 Guest are viewing this topic. Read 7512 times.
Mark,I bought a 5/10/15X (which can be turned into a 30X) at RadioShack for just a few bucks. It will get close enough for you to view your stylus.Wayner
I got a 50x optical / 200x digital USB microscope for like $20 off Amazon?
Sorry, I was wrong, it is $39.95.http://www.amazon.com/gp/product/B00AFH3IN4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Is this a general examination or checking for wear?If you want to check for wear you need a more specialized set-up with side lights. neo
Thank you WaynerIs 15X enough? I thought more of a 100X...Mark
Yes, the idea is to check for wear...ThxM
I suggest you start here:http://www.audiokarma.org/forums/showthread.php?t=225960Sparky used a Shure microscope. there were two models. One was 100X and the other was 200X.I used an Audio Technica. It was 100, 300, and 500X. It had high intensity gooseneck lamps on the side. The idea is to look at the light reflected off the side of the tip. The patch of light exposes what is called a flat, a portion worn flat and reflecting light like a mirror or flat surface. Wear is judged by the relative size of the flat(s). 30X is great for general examination. You can see if the tip is chipped or fractured except some micros are so small you can barely see the business part of the tip. I haven't looked at that Karma thread and photos in years, but I remember it's a good place to get an idea of what you're looking at. neo
