Stylus microscope
0 Members and 1 Guest are viewing this topic. Read 7541 times.
Jeff K
Re: Stylus microscope
« Reply #20 on: 22 Nov 2014, 06:53 pm »
These set-ups are good for general inspection and beauty shots, but they will NOT tell you about wear.  Believe me.  I did this professionally and you can clean up most well worn tips and they look lovely.
You have to identify the relative size of the area worn flat.  Unless a tip is completely worn out you're making a judgment call.  You can also see when one side is worn more than the other.  Usually, none of this is discernible on a beauty shot.
neo
This is the truth.
I vaguely remember a Shure guide with photos of various degrees of reflected wear-flats ranging from acceptable to worn-out. Anyone have a link to that?
Kenneth Patchen
  • Just like that bluebird
« Reply #21 on: 22 Nov 2014, 07:08 pm »
You bet:
http://cdn.shure.com/user_guide/upload/1506/us_pro_sek-2_ug.pdf
Somewhere I have a link to detailed instructions (from an AKer, I believe) for transforming an ordinary school microscope into the venerable Sure SEK-2.
A fun project if you have the time and the inclination.
KP
Kenneth Patchen
« Reply #22 on: 22 Nov 2014, 07:32 pm »
Here's the link to the AK thread for transforming a yard sale scope into the Shure SEK-2:
http://www.audiokarma.org/forums/showthread.php?t=225960 :cry:
Man, that's good work!
KP
Jeff K
« Reply #23 on: 23 Nov 2014, 03:34 am »
You bet:
KP
That's it! Thanks!
