0 Members and 1 Guest are viewing this topic. Read 543208 times.
I happened to stumble across a review on a home theater site last year where a guy was driving some Revel Salon's for two channel . He stated the Crown was the best amp he had used on the revels , even after using some real big buck amps . He described them as very neutral .Definitely can spend more on ones speakers with the savings of money . got to like that !
the Crown is good if your a dj but not for high end critical
Roscoe, What if you number them on how you like them?
Hmmm, what else am I forgetting?
Decware SE84B
I'm curious where the F series compares to the DriveCores. The F series can be built for a fairly low amount of money if you don't mind a hack-slob case. If you do, then you're talking hundreds more.
Just after only one hour of warm-up, the Salis Audio 1500 is bettering my 2500. I didn't expect that until at least 24 hours.
Care to describe exactly what you're hearing that's better?
More liquid, more articulate, the wolf on Roger Walters Amuzed to Death is now at 3 o'clock instead of 11 o'clock. Soundstage is not as forward, so the depth is farther back.
Sounds great! I assume it's better to get his mod before you get the cryo treatment, correct?
When the cryo amp comes in, we will see how it stacks up. Then the Pomona posts, and then cryo.
