0 Members and 1 Guest are viewing this topic. Read 12930 times.
Hi, Try the NAD C-510, http://nadelectronics.com/products/hifi-amplifiers/C-510-Direct-Digital-Preamp-DAC very close to the M51 but only $1,300.
I think the real solution is to go back to the days when surround sound was processed through an external box. Then you could just upgrade the box, and not have to get a whole new receiver whenever a new format was developed or improved. Such a box could also presumably have analog outputs to feed a two channel integrated amp, and not pollute it with all the digital noise from the video and other chip sets of such units.Of course this has very little probability of such actually being produced as it's in the home theater manufactures interest to move new home theater receiver models every year. About the closest thing to what I would like to have is the Oppo 105 as that unit also has HDMI inputs and can therefore do the decoding and pass the multi channel and analog out to a conventional 2 channel preamp or integrated amp. So I guess the short answer is : get an Oppo 105, plug your video sources into it, and use the left, right and sub for analog outputs to respectively your two channel preamp or integrated amp, and RCA line level sub out to sub woofer. Fortunately the Oppo 105 also happens to also be a very good Blu-ray player and CD player, which helps it to be even better value, killing three birds with one stone, so to speak.
This reasonably priced Dac/pre http://www.essenceelectrostatic.com/product/hi-res-audio-converter/ is 2ch with HDMI.Not sure why you would need Dolby/DTS for 2ch....and there is a small fringe, including myself, who consider 2.0 or 2.2 to be higher quality than 2.1. YMMVcheers,AJ
The HDMI to S/PDIF switchbox is a consideration for a 2 channel only system.http://www.monoprice.com/Product?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=2Russ
2.0 vs 2.2 vs 2.1.......isn't the point. I'm using 2.1 as everyone would understand I'm talking about at least 2.0 or in most cases where people don't have truly full range speakers then 2.1 or 2.2 can be used. Also the point of stating 2.1 ties together with Dolby processing, DTS processing and bass management DSP, which HT receivers have. Dolby and DTS decoders are necessary to decode the audio from many cable and satellite boxes as well as Blu Ray and DVD.
Looking at the link you attached, it seems as though they are depending on the cable box or Blu Ray player to handle Dolby and DTS processing.
I don't understand your issue with using a multi-channel AVR other than "wasting" the additional channels and capabilities.The reality is that a 2 channel AVR would be such a niche product it would cost much more than a standard multi-channel AVR with similar capabilities.
I think the issue is just wanting a higher quality preamp, higher quality DAC and higher quality amplifier than what exists in typical AVRs, even top of the line models (not sure about the $6K Arcam AVR-750 though), more so than wasted unused channels.I agree it would certainly cost more, but I'm guessing the OP might still go for it, were something like that available.Steve
HDMI is not the best source for quality digital audio. It's a convenient cable, but it sacrifices sound quality. That is probably why most 2 channel guys don't mess with it, and more likely if you have 2 channel, your not watching BlueRay thru it.........
Can you elaborate? Keep in mind I'm not talking about 2 channel audio only, as much as I'm talking about 2 channel HT, which is why I posted this in the HT Circle. For HT, HDMI is the standard for AV integration. That's what I want is integration without ALL the extras. I understand what you're saying and most of us 2 channel guys don't mix HT with our serious 2 channel any more than we have to. Luckily there are a multitude of ways to carefully accomplish this.
I think your best bet is to get a pre-processor, set it to 2.1 channel output and then connect it to your amplifier and powered subwoofer of choice.That way you are only paying for 2 channels of high quality amplification so no "wasted" parts here.On the processor you are paying for a bit more. Independent of volume discounts, I estimate that the saving for 2 channels vs. 7 channels would be 10% - 15%. Smaller case, fewer connectors and fewer surface mount components related to fewer channels but you still need the same processing chips, control circuitry and buttons.When you throw in volume differences it's like Gzerro says.
