0 Members and 1 Guest are viewing this topic. Read 15560 times.
Electron Kinetics Eagle 2 -- that is if you can find one.
Wind Chaser, thanks but no integrated amps please... I have a nice preamp that will be used with the amp. I have not seen any Electron Kinetics amps around but I'll look into it if I do.Hugh, I'm willing to consider any suggestions... I only saw one Sunfire amp around so far and it was pricey.geowak, have not seen an A21 but there is a "classic 2250" on agon right now, is that as good? Nevermind... saw an A21 on ebay and it's $1600... definitely does not look comparable to the 2250.viggen, will keep my eye out, thanks!
Another amp to consider if you want a ton of power is an Emotiva XPA-2. I have not heard one but they have their following. It is probably as good as the Classic 2250https://emotiva.com/products/amplifiers/xpa-2I have a Parasound A21 amp that I use in a secondary system. It is a very good amp but I don't think that you will find one for $1K. The Classic line is very good though.I would try negotiate a price on that Odyssey amp as you can get a brand new Stratos for for $1375
An A23 might be a good alternative, but I'm not sure if it has enough power for you.
Check out some of the Pass Labs or First Watt stuff. Might find a good diy one for sale. Your very efficient speakers are calling out for some Nelson Pass magic!
