0 Members and 1 Guest are viewing this topic. Read 15559 times.
I have heard Emotiva is very good bang for the buck (or watts for the buck), and they are not class D. I do not own one but I am considering one for a second system.
I think they are clearing out the old XPA-1L monoblocks which put out a good amount of Class A watts. I don't think you could go wrong with a pair of these, which are $1k/pair. (I thought I saw them on sale $399 each, but maybe I made that up).http://emotiva.com/products/amplifiers/xpa-1l
I looked at the Eagle 2a on ebay and I'm not sure it's what I'm looking for given the reviews (forward, sounds like SS) and it would also need to be re-capped... but I could buy it and order the parts kit for around $850, which was about the retail price of that amp way back in the mid-80's. There is a Parasound A23 around, going to look into that one for sure... I also think the Proceed BPA-2 would work well and there are a few for sale. I think the most I'd want to pay for that Odyssey is $800ish, pretty far from the $1200 asking price.The Emotiva BPA-2 does look like a great deal for a 300 wpc amp that can be bridged to 1kW. Will have to read some reviews...
Check out some of the Pass Labs or First Watt stuff. Might find a good diy one for sale. Your very efficient speakers are calling out for some Nelson Pass magic!
You might read around on the Proceeds. From things I've read, they haven't aged well despite their pedigree, and often require recapping......which seems strange to me because I've seen many much older amps not need a recap for 20+ years.
Yamaha A-S2000, perhaps?It is slightly over your budget but not by much, and I think you can get refurbished/used models in the $1k price range.To be honest, I haven't heard it myself, but a friend of mine has it, and I have been following its reviews. It seems to be a very good integrated amp - and looks like a steal at this price range. Is also supposed to be fairly transparent and neutral sounding.
Any desire to build your own solid state amplifier? You can pick up a couple of PCBs from diyaudio (VSSA recommended), populate it, attach a SMPS from connexelectronic.com, then build a chassis.I run something similar and it works extremely well.
