0 Members and 1 Guest are viewing this topic. Read 10222 times.
hi my name is Mark I am a new member to this sitemy question is in regards to two of the Carver m1.0I own they are currently not in use at this timeis it worth it to send the amps out to a place in Oregonthat does a complete chassis upgrade along with cap upgrade order would I be better off saving that money and putting it towards a new amp thanks for any advice
I firmly believe a refurbished Carver M 1.0 t will run with the big dogs. Recapping and modifying the amp to the MK II level will give you a most satisfying powerhouse of an amp. Carver topics always run crazy so beware. I recently had that amp (refurbed) in my systems. It was wonderful. All older SS amps with aging caps will sound poor. I listened to that amp through B&W speakers, VMPS speakers, Carver Amazings and , AR's with great results. I preferred my CJ preamp over the Carver C1 but the combo was glorious. Huge power! If you would like to sell your carvers PM me.
Thanks to all the feedback and advise I am in the next few weeks going to be able upgrade my current preamp and cd player to a Rouge Perseus magnum preamp and a Rega Saturn r cd player after that it will take about a year to a year and a half to recoup from that expense and save up enough for the amps I am interested in but there would be enough to upgrade the two m 1.0 amps about $800.00 with s&h I just wanted to get feedback if I should save the money I would use for upgrades and save it for amp I want.I am looking at the Rouge audio stereo 100.
Let me decide for you. Get the Rogue!
