BDP-1USB Digital Player
0 Members and 1 Guest are viewing this topic. Read 14443 times.
mr_bill
Re: BDP-1USB Digital Player
« Reply #1 on: 3 Sep 2014, 05:28 pm »
Nice.......then this model only has a USB output rather than spdif, aes, etc?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 3 Sep 2014, 05:47 pm »
Hi Bill,
Correct - USB only - no AES or BNC and no Soundcard.
james
Rod_S
« Reply #3 on: 3 Sep 2014, 06:26 pm »
Very dumb question but what is the soundcard used for in the BDP-2?
ttsto
« Reply #4 on: 3 Sep 2014, 06:42 pm »
Rod_S
« Reply #5 on: 3 Sep 2014, 07:07 pm »
I'm assuming this is what converts the digital files and outputs that signal to the likes of spdif, AES/EBU, toslink etc.
« Reply #6 on: 3 Sep 2014, 07:21 pm »
Correct :thumb:
james
Rod_S
« Reply #7 on: 3 Sep 2014, 07:39 pm »
Correct :thumb:
james
Thanks, at least I was able to put 2 and 2 together myself :D
Samurai7595
« Reply #8 on: 4 Sep 2014, 03:13 pm »
« Last Edit: 4 Sep 2014, 06:58 pm by Samurai7595 »
mav52
« Reply #9 on: 4 Sep 2014, 04:07 pm »
Interesting player
alexone
« Reply #10 on: 4 Sep 2014, 08:04 pm »
...nice, Bryston! and keep on creating :thumb:
al.
amblin
  • 'On the cutting edge of cocking about.'
« Reply #11 on: 4 Sep 2014, 08:10 pm »
So this will replace the computer in the system? A 'digital transport'?
I wonder how do I navigate all the songs? Is there an optional tablet controller or iPad support? I hope it's not like those DAT players i used back in the days... The menu system was almost impossible to use on the tiny screen...
« Reply #12 on: 4 Sep 2014, 08:50 pm »
Hi
Works the same as the BDP2 - you can use IPAD or IPHONE or Computer or Android device etc.
james
KingstonMoon
« Reply #13 on: 4 Sep 2014, 10:54 pm »
Great news !!  okay - so i was going to get  BUC-1 to play into my 300d version 1 moon -- sold the moon to make way for a Bryston kit top to bottom .
So this is the plan - I can do the macbook  into the BDP-1USB  - then into the BDA-2 dac - into a BP26 - and then the 4BSST2, and then out some Bryston speakers .
Is my thinking clear on this ?
Will the BDP-1USB come in black ?
« Reply #14 on: 4 Sep 2014, 11:57 pm »
Hi Kingston
Yes Black or Silver 17 or 19 inch faceplate. BUT - the MacBook is replaced by the BDP-1USB.  If you want to use the MACBOOK then just get the BDA2 DAC and use its USB input.
I thought you bought some Mini T's a while ago?
james
KingstonMoon
« Reply #15 on: 5 Sep 2014, 12:21 am »
Hey James !  big thanks !  So the position the BDP-1USB plays is designed more towards those tying a file storage drive to it - then send data down stream to dac ?   Okay - that helps my budget . So i can remove the BDP-1USB from my grocery list
Speakers were this close - and i was smitten and in love with them - still am - then an S4 sedan took my money lol , but you have since added more to the line - so i have to dial in again where i want to be -- I'm now gun to the piggy bank as i sold my PMC - and i need my hifi back real bad !! i have a TFSA just for hifi lol  . If i don't need the new device I'm even closer to ordering a full kit - then speakers !  My Moon gear has also gone to a new home .
HIFI rack awaiting new components - and the insurance on new kit is cheaper than the harley i wanted ! Wife will be happier lol
Steve Bruzonsky
« Reply #16 on: 6 Sep 2014, 01:12 am »
Can this new digital player deocde ripped SACD ISO stereo tracks to 176-24 or 88-24 or by DoP to a compatible DAC?
R. Daneel
« Reply #17 on: 6 Sep 2014, 01:03 pm »
Hi James!
Since the Bryston hasn't been updated yet, can you give us a technical brief on the specifications of the BDP-1USB. Is it basically a BDP-1 with no included sound-card or was it perhaps derived from BDP-2 with it's greater operating speed etc?
My estimation would be that it's the former.
Cheers!
Antun
« Reply #18 on: 6 Sep 2014, 01:28 pm »
Hi James!
Cheers!
Antun
HI
It is the BDP-1 with no soundcard or AES or BNC out.
james
unincognito
    • bryston.com
« Reply #19 on: 6 Sep 2014, 01:50 pm »
No
